Question about Hitachi THE SOLUTION 3511 Projector, Mount and Vutec Theater Screen Package Multimedia Projector
Red Lines On Screen of Hitachi 43FDX01B
Help! On the screen of my TV (Hitachi 43FDX01B) there are these crazy horizontal red lines. Some of them are crossing at the bottom of the screen and then towards the top they curve upwards going from left to right. It happened once or twice already and it fixed itself, but now they're not going away.
I also have the same problem. I've found that you can adjust each color of the screen by removing the speaker cover. Underneath you'll find a piece of partical board. Remove it. Looking at the front of the T.V. from left to right you will see the projector assembly for each color, red, green and blue. There are about six levers that pivot around each assembly. There factory settings are marked with white paint. By turning the ones on the red projector only you can manipulate the reds alignment on the screen. I don't know if it will work yet. My wife is the middle of adjusting. If anyone has a better solution please post it. I love my T.V.
Posted on Apr 15, 2007
    President:
  • 3,130 Answers
Can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Posted on Apr 26, 2006
SOURCE:
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Red line on screen
something going on w/ the convergence take to tv shop before it will cost lot more good luck shad
May 03, 2009 | Hitachi 43FDX01B TV
Convergence lines on the Hitachi 43FDX01B
Download this manual:-
http://schematicsforfree.com/archive/file/_newly_uploaded/Hitachi_DCAM_Manual.pdf and do the Red touch up on page 63. However I would read the rest of the manual as well so that you get the full understanding.
If you still cannot converge the Red then you will need to replace the two Convergence IC's and associated resistors. Details of how to do this are here:- http://www.digitalhome.ca/forum/showthread.php?t=21847
Remember that there are VERY HIGH VOLTAGES present in an RPTv even when it is disconnected. So disconnect it from the mains for at least 4 hours before you enter the set, this will give time for the high voltage to discharge.
Jan 31, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B convergence red line wont move
probably need to replace STK IC on convergence board and possibly associated low value resistor
May 09, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
I have a bend horizontal red
Convergence problems, sounds like you need the kit.
Dec 22, 2007 | Hitachi 43FDX01B TV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Red CRT is going out
One of the convergence IC's is going bad and needs to be replaced.
Nov 15, 2006 | Hitachi 43FDX01B TV
402 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
