Question about Honeywell Heating & Cooling
I tried to replace my thermostat with a reprogrammable one and it didn't work. I reinstalled the old thermostat and it will not even read a temp or show any signs of life. Can you help me?
  • 58 Answers
It makes a difference if you have elect or gas. you have to use a thermostat specific for your application. also it is possible the you burnt out the heat anticipator.
Posted on Sep 11, 2008
Honeywell rth7400d
your thermostat is getting bad and cannot get temp very well either due to batteries or old life try getting a new one
Dec 17, 2013 | Heating & Cooling
2001 chevy malibu temp gauge stopped working.. car didn't run hot but coolant was also empty. But saw a signs of a leak. Replaced coolant and after 20 mins.. gauge worked again.. not sure if it was a...
With no Hot Coolant going past the Sensor, you get a false reading.
Low coolant is why the sensor wasnot telling you the engine was running hot.
Oct 03, 2012 | Cars & Trucks
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Thermostat on dashboard not moving even after thermostat and sensor replaced
either you didn't replace right one or the gauge is bad. yes there are 2 sensors for the temp assy, one is for fans, one is for gauge.
Jul 25, 2011 | 1990 Honda Accord
Just put a new thermostat in, & its still over heating
Make sure you didn't put it in backwards. Even after working on cars over the years I have been known to make those minor mistakes being in a hurry. If you have an electric fan make sure it's working. Once your car reaches a certain temp it should kick on. I would yank the thermostat and flush the coolant system with a kit you can get at most parts stores. Run it without the thermostat and see if it's still overheating. If no then reinstall the thermostat. If yes then it would most likely be your water pump.
May 27, 2011 | Ford Escort Cars & Trucks
We have a Jenn-Air electric slide in oven, model W131. It appears to work fine in all respects except that it doesn't come up to the set temp even though it tells you it has. Set at 350, it notifies...
if you changed the sensor most likely it will be the clock assy.it's not just a clock it also has a computer board built into it.you're missing a few letters off of the model number so when you call your parts store give them the full model number so they will sell you the right clock assy. i believe your board is around 150 dollars.if the elements are good and a new sensor all that's left is the board or clock assy. good luck with your stove.
May 23, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Heater will not get warm even after running engine it will heat when the weather is warm but when temp drops and it is cold it will not heatchanged thermostat, checked hoses,
did you install correct temperature thermostat? also is the temp guage in the car working and what does it read, if it reads a normal reading then the fan may be working improperly.
Dec 13, 2010 | 2000 Dodge Stratus
Temp gage in cluster shows the temp cold all the time. 2008 ford focus se. Dealer just replaced the thermostat, didn';t solve problem.
change your dealership ,infact i would say this is not a ford reconised dealer ship,it might advertise ford full stop.Any good dealer would reconise this problem as the switch and i have taught 16/17 year old who would have had your problem fixed and sorted in 10 mins.adrian,,,,,,,,,,,
Aug 21, 2010 | 2008 Ford Focus SE Sedan
Wrong temp. on the thermostat.
sometimes a power outage or a static spark will effect the stat, remove the stat from the wall take out the batteries and walk away from it for at least 10 minutes, then reinstall it
Aug 03, 2009 | Heating & Cooling
Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
May 29, 2009 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
