Question about Maytag HYG2460AWW Gas Dryer
My Matag dryer does not run, but for a while it hummed before starting.
For several months it has made a humming sound before starting, and sometimes took a while to kick in and work. Today, it hummed for quite a while when I pushed the button, but then it totally stopped working. The woman at the parts store suggested a start switch, but also suggested it may be the motor. They do not have the switch in stock so I will need to order it. Is there anything else I should try?
  • 2 more comments
  • Agazi Dec 30, 2007
    i have a drayer working properly but the clothe are not drying, i guss it looke like the hummed control not woriking. if you have some idea please share me ,thankyou.
  • DoreenD Mar 23, 2008
    My Frigidaire wasn't drying well for a couple of months and then it wouldn't start. I cleaned all the lint from the dryer and the vents and it was really clogged. The drum was very difficult to turn but I finally got it to run. The clothes dried quickly, better than ever. I went to do another load and it wouldn't start again. Do I need to buy another motor or is there a part that can be replaced instead. What would be easier ?
  • Anonymous Apr 07, 2008
    my dryer was on dried all the clothes i put the next load in and it wont turn on
  • dundar Apr 19, 2008
    my dryer is making a humming noise when the dryer is on, it seems like the close don't dry all the way.....sometimes they do tough...what can i do?
  • 29 Answers
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Posted on Jan 07, 2008
THE DRUM MAKES A SQUEALING NOISE WHEN IT RUNS
Posted on Dec 10, 2008
The likelyhood there is a start cap. is low. if its a high end dryer it may have one but the units I work on do not. My guess is a poor start winding in the motor.
Posted on Nov 12, 2007
Capacitor on the motor is faulty.the humming is the motor trying too start.it will be an inexpensive repair
Posted on Mar 29, 2007
  • 641 Answers
It doesn't looked like a switch problem. My suggestion : - open the drayer and see if the belt wrapped properly arround motor's pulley and drum and not torn. - Check that drive motor (located on the bottom left side) is turn while operating the dryer. In case the motor is not working, test that he get power. If he receive power - It means the motor is defective. In case he doesn't get power - It look like a switch problem. Good luck.
Posted on Apr 11, 2006
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dear Expert, When I went to turn on my Roper dryer it made a humming sound for a few seconds then quit, without out the dryer ever starting. I then had my wife depress the start know while I held the...
check and see if there is any thing in the dryer vent if not.open the door hold the door switch in like the door is shut.have your wife push the start switch in and turn the drum counterclock wise if it starts then the motor has gone bad if it hums still its still the motor.if it does start stop the dryer and try restarting several times sometimes they get a dead spot and it may work for years or may die tomorrow but these are a couple of things to try good luck
Dec 19, 2010 | Dryers
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Dryer won't start
sounds like the start windings in the motor have failed you will need a new motor to repair this.
Jan 22, 2009 | Dryers
Starting dryer
you need to replace the motor
Dec 17, 2007 | Dryers
Starting dryer
the motor needs to be replaced. the bearing are going bad and they are only sold as the whole motor
Nov 28, 2007 | Dryers
Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Sep 17, 2007 | Dryers
Maytag HYG2460AWW Gas Dryer Logo
1,184 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
