Sorry to hear that you are having trouble with your Bose system. Since it is turning off real quick it sounds like there may be a short in the system. The thing to remember about most modern electronics is they do not have a physical on/off switch. The power is controlled a circuit. Connect the circuit to turn on the device and connect it again to turn off the device.
So the short can be causing a ION charge on the board and after a certain point the charge gets strong enough to connect the circuit which turns off the device.
Now if you are lucky the issue is with the fuse not connected properly and it is just arching in the cradle because it is not connected properly which is causing the arching across the connector. I had a TV that had that problem once.
So what I would do is contact Bose to make sure that you can not get warranty service before opening the unit. If you can not then I would check the fuse and make sure it is connected good.
Hope this helps.
If you have any more problems and/or questions let me know.
Random is truly a difficult problem to solve, if no pattern of failure can be detected. It sounds as though the alarm may be at fault. Is the alarm on and set to radio, CD, or beep? If radio, that could pinpoint the problem. If you have another, mechanical alarm, use it for a couple nights with the Bose Wave alarm off. If the Bose still acts up, then it isn't the alarm. Try unplugging the unit, waiting at least 30 seconds, and plugging it back in, which will cause you to need to reset the alarm. Alternately, remove the Bose cover and blow out dust. I find the Bose susceptible to dust as a cause of malfunction, which may point to the cause being the compact design of the unit. Good luck.
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP If it's the Bose itself then the main amp inside has failed.
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
If it's flashing on and off, then the DVD drive is the least of your problems. Check to see if there is a dual-voltage switch on the bass module. (if so, set it to 120v if you're in the US)
As for the DVD drive--> Try another reset by unplugging the power for at least 30 seconds. Plug it back in, "Bose 321" will appear and disappear from the display, and then press the eject button before you power it back on. Wait about 3-8 seconds. If the drive won't open, it will probably need a repair.
$150 for repair w/ new warranty through Bose- 800-367-4998.
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
you can set up any like this 1. turn on what ever you want set up 2. press and hold set up tell light blinks or stays lit 3. push what you are trying to set up t.v. or dvd ect. 4. push power on/off tell it turns off 5. push enter when it turns off Thank you for useing fixya please rate me
This was posted a while ago, so I'm sure it's probably been solved by now.
For anyone with audio issues using this or any other Lifestyle system:
If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
you need to bring the head unit and the bassbox back to bose for service or repair, it is aproblem with the powering up of the amp module, and could be caused by the control circuit in the haed unit or a problem in the amp, which has a slow ramp function to prevent louds bangs and pos at start up. in that case i would guess the latter is faulty, i would guess it is also a warranty repair for bose too.
