Question about Sony PlayStation 2 (PS2) Console
Ps2 damage i took apart my ps2 and put it back together right , okay , when i turned it on, the menu looked different , you know when it loads up that blue and purple thing spining around , well it spins around at start up but 2 seconds later it just goes to a big blue dot , my ps2 was NOT acting like this before i had taken it apart , so do you think i should get a new motherboard or just check the wires and stuff? please reply if you can help me. thanks.
  • magicalmatt
    magicalmatt Sep 12, 2008
    thank you man , i couldn't find anyone else that knew what i was talking about.
  • Sony Master
  • 19,396 Answers
It looks like you damaged your PS2 firmware, if this is the case you will need to have it reflashed at a sony repair centre.
Check if connectors to video and cold solder joint to video output are ok, test capacitors and resistors for continuity, using a multimeter, see if you find some cap that has blown, that will be luck.
If you do not find anything, it means that you have damaged some of the ICs, probably by touching the board with bare hands and causing electrostatic discharge on IC contacts.
This can be fixed only at a Sone repair centre.
Ask to retailer or call the number listed on the PS user manual, if you are lucky you can purchase an extended guaranty for $80 and have it fixed for free for the next two years, or if the PS is less than one year old you can use your current factory guaranty.
Call Sony and ask.
Posted on Sep 10, 2008
Ps2 slim scph-75001 starts to read the games but then stops!
your lense is more than likely defragmented jacob and you should never take any system apart okay so what you wanna do is if your warrenty is still in effect dont tell sony you took it apart just send it in for a refurbisment if it isnt you need to look around online for a ps2 slim lense okay
Mar 08, 2009 | Sony PlayStation 2 (PS2) Console
hi there there are loads of videos on you tube that shows you how to put this back together make sure you look up the right ps2 ie ps2 or ps2 slim they both open and come apart completely different
hope this helps ya a little
Feb 06, 2009 | Sony PlayStation 2 (PS2) Console
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
PS2 "Slimline" Can not read disk?
the problem I had is my ps2 slimline wouldn't play ps2 games. so I went on line and followed instruction took it all apart cleaned everything nothing. put it back together, for some reason I openned the ps2 where the disk goes there you can see the eye, I took a small flat heat screw driver the ones you use to fix eye glasses, and put it under the eye assembly and so gentle pushed it up. now it works perfect. not to hard you don't want to break it, I didn't even see it move. Hope this helps
Dec 03, 2007 | Sony PlayStation 2 Slimline Console
PS2 won't work, red light comes on, buttons don't respond
Sounds like the ribbon cable is ether damaged or not in the slot all the way.. that clicking sound you hear is common after extended use, all mine make the same sound ..try opening it up one more time and check the ribbon ends i know it's a pain but might be worth your time. pulling them out too hard can damage the ends.some time's putting them they seem like there in all the way but it might not be in straight.REMEMBER BENT FOLDED FLAT CABLES = problems.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 not working
He forgot to plug up the power cord inside.
Nov 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact
Nov 07, 2007 | Sony PlayStation 2 (PS2) Console
PS2 wont spin games
if it reads the silver ones it should read the other i would have said change the laser but as you have done this i could be that it has over heated and their is no way of curring this have you tried playing the blue ones on another ps2 if this is not the problem then their is nothing you can do other than sell yours for spares or buy a broken one you can get them off ebay cheap as you no your laser works usually the one people sell that dont work is the laser so you could put the laser into the one you buy then you should have no probs sorry this isnt nothing else you can do
Oct 29, 2007 | Sony PlayStation 2 (PS2) Console
Double vision
it looks like when you took this apart you did not alignt the lenses properly, there should be a locating groove or stub which these lenses should fit to... it looks like they are pressing against the stub but are not located properly, hence the distortion. try taking it apart again....when you put it back together again the fault may have gone.
Sep 29, 2006 | Wesco WS7 Microscope
Sony PlayStation 2 (PS2) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
