Question about Garmin Touch Screen GPS Receiver
Nuvi 350 Garbled voice
Garbled voice comands
  • Garmin Master
  • 2,130 Answers
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Posted on Sep 11, 2008
Can not get voice comands
if you mean like "turn right on Madison" as an example, you must have the tts voice selected ...that is the computer generated voices...it will not work with human voices....
go in the system setting and go to the voice option, and see if you have any TTS voices...if not, they may have been deleted..if so, go HERE and download the web updater and 1st see if there are any updates, then after that it will give you an option to add voices...just select one or some that are TTS...after there loaded to your gps, go back in the voice option and change it to one of the TTS voices.
if you mean you have no sound at all, post back and i will help you further.
bill
Jul 07, 2010 | Garmin nuvi 260W GPS Receiver
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
How do you switch voices on a nuvi 350
Go to Tools.....Settings....Language.... under Voice make sure Language with ( TTS ) is chosen
Feb 06, 2010 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 760 audio i dont have voice comand
got to Tools... Settings... Language.. select a language teat ends with ( TTS )
Feb 03, 2010 | Garmin (010-00583-00) for nuvi 750/760/770
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
INTERNAL SPEAKER NOT WORKING GARMEN 660
The garbled voice has nothing to do with the map update. You internal speaker is defective. Please see this link to see more info on this problem.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Sep 04, 2009 | Garmin Nuvi 660 GPS Receiver
The voice stopped working on my Garmin Nuvi 350 in mid sentence
what has happened? my etrex said low batteries. I changed batteries. now all I get is searching for sattellites? can anyone help?
Mar 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 - How do you get it to say the name of the street?
You have to select one of the "TTS" voices (TTS stands for text to speech). These are the voices capable of saying the street names (although the mispronunciations are often amusing)
Nov 29, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Touch Screen GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
