Question about Mitsubishi VS-6043 60" Rear Projection Television
Mitsubishi vs-6043 turns itself off.
I have a problem with my t.v. when i turn it on, it immediatly turns itself off. no funny wierd noises or anything, but it just wont stay working.
    President:
  • 3,130 Answers
On this set it could be 1 of 3 common problems. first it could be the regulator ic in the sets power supply. It could also have a shorted horzontal output transistor because of cold solder connections on the horizontal drive curcuit. and finally could be cold solder connections on the colis and or the high wattage resisters in the sweep power supply and horizontal output section. You should first put the set if you can on a variac transformer and lower the ac voltage to 85 to 90 volts ac and see if set comes on. If it dosent static check the voltages on the pwer supply when powered up if they are there then check the horizontal driver and output problems.. If you understand what im saying and have the proper tools good luck to ya but if you dont it would be best to take or have a pro come and check it for you.
Posted on Apr 10, 2006
MyMitsubishi VS-6043 Big screen TV just started to black out while we were watching it.I would turn it off and back on the picture would be there. Now the power light goes on but the screen is black. Is...
Not sure on that one. My local repair guru tells me the 6043's are constantly having problems. I've got one that I'm looking for board parts for, so if you end up not wanting to fix yours, I'd love to get your board set for some parts.
Nov 11, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
6043 6061 parts interchange
Well, you can use most of the parts, except that the shape of the boards are different, so you cant exchange the entire board as such.
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Will vs-6043 parts interchange with vs-6061
What specifically are you looking to interchange?
No picture or sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
