Paragon alarm code
I have a paragon alarm system but as i only rent the huse the agency dont no the code can i reset it
I have recently moved into a new property and it has a paragon plus alarm system fitted. I have tried contacting the previous owners for the alarm code, but to no avail.
Does anyone know a way around this problem?
Posted on Sep 26, 2008
Unplug the alarm from the transformer and leave for a week then reconect and use the factory set master code which is 1234,
Posted on Feb 19, 2010
Paragon alarm instructions
To reset turn power off and remove cover, Remove battery and then remove small black jumper from the middlle of the cicuit board. Power back up with battery and put jumper pin back.
Code will be 1234 for user code and 9999 for engineer code
Thanks\
firoz
Apr 30, 2014 | Computers & Internet
Is it possible to get a house for rent only for 8 months in dubai/bur dubai?
However, depending on your situation you might consider the option of sharing accommodation - where you share a room in a flat which is rented (on contract) by another person. There is also the option of renting serviced apartments on weekly or monthly basis but this is generally expensive for long term.
Another point to note: rents in Sharjah ( which is adjacent to Dubai and actually just 20-30 minutes drive from Dubai but takes upto1.30 hrs to get into Dubai during peak hours) is much cheaper. buy youtube views A 1 yr contract in Sharjah may be less than the 8 months rental for similar accommodation in Dubai.
Aug 30, 2013 | Cars & Trucks
1997 dodge stratus agency alarm came on now car seems to be blocked it turns on but then turns off and the alarm keeps honking when i turn the ing switch to on position the lights,door locks,stereo and...
You need to get the alarm system reprogrammed. I don't know your personal code. It may be in the owner manual. If not, you will need to call a Dodge dealer.
Feb 15, 2011 | 1997 Dodge Stratus
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
I need a manual for a bmw 316i compact 1996
These can be bought at most discount parts huses, e.g. Autozone, Advanced Auto, O'Reilly's, and Pep Boys for about $20.00. Haynes Service Manual:
Apr 07, 2010 | BMW 3 Series Cars & Trucks
Doors will not open using remote or disarm alarm. unlocking with key and as soon as door is opened alarm is activated , have replaced batteries in keys
You must enter the system using the EKA code, it will written in the service book how to activate the EKA. If you dont have the EKA code, you will have to take the car to the dealer to reset the system and give you the code. hope that helps
Mar 15, 2010 | 1999 Land Rover Discovery
I have a Bosh solution-16 Home security system which was there when we moved to our new house. The problem is that the access code was unknown. Therefore I manged to reset it from the main board. and the...
I know you don't want to pay an alarm technition to solve your problem....thats why your here, but in this case, I dont recommend you do this yourself... Call an alarm specalist, Some of these alarm panels require specalized programming and specific access codes you won;t be able to get a hold of. All of them are different. The safety of you and your family is worth more than a $75.00 service call.
Aug 30, 2009 | Code-Alarm Code Alarm Transponder
Dont know the reset code or anything about home security alarm sy
need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
Apr 23, 2009 | Electrical Supplies
Computers & Internet Logo
597 people viewed this question
David Payne
David Payne
