Samsunghlp5063wx/xaa Well I've been at this for a week or more now. My Tv had audio and no picture I heard a light hum louder than before but not very noticeable. and all three LEDs where flashing/blinking I assumed the bulb was good because i saw the bulb fire up when troubleshooting the issue. I have since replace the color wheel and now have only the lamp led lighting up with only audio and no picture at all. Should i replace the bulb and do you think my colorwheel was bad too and also can both go out at the same time?
    Novelist:
    Champion:
  • 203 Answers
I have several concerns with you problem. First did you double check to make sure all the wireing is pluged back in correctly? Second are you aware of the interlock switch on the back of the set?(this is a small blue swich that if you are behind the tv you should see a little right of center in the back on the bottom, if you dont knwo what im talking about let me know and i will try to get you a picture of one) if you do not put the back to the set back on or push that switch in then the set will not come on. You said you have replaced the color wheel already so i do not think that you new one is bad. If you have already made sure the wireing is good and that interlock switch is engaged then you could have a bad lamp or ballast as crazy as it seems.
Thank You
Tim
experttv@comcast.net
Posted on Sep 11, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
No picture but I have sound. Also a lamp light blinking green.. . ? This is on a SAMSUNGHLP5063WX/XAA
Suspects in order of being likely:
Lamp
Lamp Ballast
Color wheel
let me know if you have questions.
May 03, 2012 | Samsung Televison & Video
When I connect the handicam to the tv there's a low hum. When I press play the hum gets louder and the picture is distorted. Any idea what is causing this?
Could be feed back from the drum assy(video head) going bad. Make sure that the 2 devices, your tv and camcorders audio are in sync by turning the audio all the way up on the camcorder and then turning your tvs audio up as loud as youll listen to it then backing the audio down with the camcorders controls. If that doesnt get it then your video head may be going bad. I hope this helps.
Sep 06, 2010 | Sony Handycam CCD-TRV68 Camcorder
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My picture won't show after replacing the lamp
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Jul 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
AKAI 54" Big screen, Turn TV on picture no sound, then within a few minutes humming sound gets louder then stops and starts
Sounds like the audio amplifier circuit is bad. I do not know if where that is in that TV. If you were to hook a boom box or stereo receiver to the TV (via the audio out jacks on the TV), you could monitor the sound that way. If you get clean sound, then the problem is in the amplification circuitry. If you still get humming, etc., then the problem is further upstream.
Also, clarifying... the picture has not changed one iota, correct?
Mar 05, 2009 | Akai LCT2715 27 in. LCD Television
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Hi I bought a Panasonic 42 Inch class 720P Plasma HDTV TH-42PX80U, the picture is fine, but there is a humming sound in the background of the audio. The louder I turn the tv the louder the hum. I tried...
If turning up the audio amplifies the problem, it is in the initial stages of audio. It could very likely be outside the TV, try difference sources to troubleshoot your setup. If it hums on all inputs, the problem is before your audio switch and could be on the board with the AV jacks. Note all plasma tvs hum out of the back of the tv (ie power board, y-sus, z-sus board and panel all make a little hum noise)
Dec 06, 2008 | Televison & Video
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
