Question about HP Laserjet M1319F Laser Multifunction Printer
Can't make copies
We try to make copies - the green light blinks, says copy pending, the light stops blinking and nothing happens.
  • 3 more comments
  • mares1083 Sep 11, 2008
    Still can't make copies.
  • Portenga_Mfg
    Portenga_Mfg Oct 06, 2008
    I have the same issue. I have found a work-around, though I shouldn't have to do that.
    Until I find the solution, I just turn off the printer and then turn it back on. That seems to reset the printer and allows me to make a copy.
    It's a pain to do it, but at least I can copy until I find the real fix.
  • Anonymous Nov 07, 2008
    cannot make copies. ready light blinks, screen says "copy pending", then nothing! This is a brand new printer
  • Diane Cou28 Nov 30, 2008
    I don't have any problem with the send and received fax, it's working find, but I can't make copies until I install the CD software. I have tried many many time to install the software and once I connect the USB cord ( it thinks for a few minutes) a small window message says "Setup Failed due to Plug and Play error and will be canceled. Please try to run septup again later" . Can someone help me with this problem, my HR LaserJet M1319F MFP is only a few days old.
  • Anonymous Jan 21, 2009
    I am having the same problem with M1319f where it does not copy - it just states copy pending. We do not want/need to connect it to the server. Any suggestions?
I had the same problem just yesterday. Turn off the printer for 10 seconds. Then turn back on. Turn back off again and unplug from the electrical outlet. Open the control panel and tilt it toward you. Close the control panel, plug machine back into the outlet and turn back on. I did this and it solved my problem.
Posted on Jan 22, 2009
  • Sisetta Nov 23, 2010
    First problem in 2 years HPlaserJet M1319 for making copies. I turned it off and unplugged from the electrical outlet just one time and it is working. I am happy that I used this web site. Thank you.
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Mar 23, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Savin 2545 communicating light blinks but nothing prints
YOU NEED YOUR FIRMWARE UPGRADED BUT ONLY A SERVICE TECH CAN GET IT AND DO IT.1 HOUR OF TIME SHOULD BE PLENTY AND THAT SHOULD INCLUDE A CLEANUP PROBABLY ABOUT 150 TO 200 DOLLARS
May 18, 2010 | Savin 2545DP Black and White Copier
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Al-1641cs can't scan
Dear Zaara.
Please try to copy (xerox) stand alone using printer and if it is copying correctly then the issue could be with the printer software in this case please email me if you need further assistance or you can call me on 9390111676.
If you are unable to copy stand alone the issue could be with
printer.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Aug 02, 2008 | Sharp AL-1641CS Laser Digital Copier
HP psc 750 printer
my computer said that it did not have it on the computer I've used the CD .
May 21, 2008 | HP PSC 750 All-In-One InkJet Printer
HELP!
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
Happy New Year
John
Dec 28, 2007 | Canon BJC S300 InkJet Printer
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Copy problem
i think that u have pending work out there!
look in ur task bar n u'll c the icon - right click on it n u'll c all ur pending work!
u hv 2 cancel or restart ur pending jobs!
BUT the best solution is to press the cancel key 'X' on ur printer after loading papers into ze tray!
HOPE it'll work n blinking will stop!
Oct 12, 2007 | HP DeskJet F380 All-In-One Printer
HP Laserjet M1319F Laser Multifunction Printer Logo
683 people viewed this question
Ben Johnson
