FixYa.com
Tags:
Canon ZR10 Mini DV Digital Camcorder
Cassette jam (by 3 users)
posted by domo on Apr 10, 2006
the cassette door opens and i hear particle inside moving but the tape won't eject. please help!! im trying to shoot a mini movie
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by bunyo, posted on Apr 04, 2008
i have a small rubber piece came off of some thing inside the camera it's about 3/4 incch long now the reject cassitte comes on as soon as you turn it on i can't see any picture and it will make a howling noise
Comment by Guest, posted on Dec 10, 2007
eject mechanism is locked - will not open to receive cassette. Battery and dew clog lights blinking.
Best Solution
posted on Apr 12, 2006
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6661 votes
Have you tryed to press the power button and the eject button at the same time when the units off?? If that dosent work the tape mechanism is jamed because of a mechanical falure or the tape its self BUT I do not recomend you try to get it out yourself as i,ve seem many many camcorders that cost 3 to 4 times more to repair because more damage was caused by the customer trying to get the tape out. Unless you have to get out the tape for personal reasons(lol) Then take it into be serviced please.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 23, 2007
FixYa! (100)
Berean
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Solution #3
posted on Dec 19, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
My JVC mini DV cmcoder(GR-DVL-300) while connecting to usb port is not been recognised by my laptop.My 3 layer stereo small pin type plugcable has a usb end.How to get jee1354(iam not sure about this number) soft ware.I have been using this coder in my P III -windows 98 desk top previously using 9 pin serial port connector.Pl advise.
Solution #4
posted on Apr 24, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
EXCELENT .
i sended it to techservice but they dont got a clue...
the i just tryed these many forms of hold eject button and turn on etc etc etc...
and WORK!!!
hehe
Solution #5
posted on Apr 02, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Mine MV3i does the same thing. I paid for a serviceman to quote for repair - A$450 for mechanicals and electronics! The camera is only 10 tapes old and well looked after....
Solution #6
posted on Apr 01, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
This happens to me once in a while.
2 ways to resolve.
1. Depress the tiny Reset button.
2. Power on camcorder...remove battery...wait 5 seconds...replace battery.
This usually resets the mechanism.
Good Luck,
Nick
This Problem Also Relates To: Panasonic Palmcorder SDR-H18 Camcorder Panasonic Palmcorder PV-GS15 Mini DV Digital Camcorder Panasonic Palmcorder VDR-M30 DVD Camcorder Panasonic Palmcorder VDR-M50 DVD Camcorder Panasonic PV-GS2 Mini DV Digital Camcorder Panasonic VDR-D200 DVD Camcorder Panasonic AG-DV1DC Mini DV Digital Camcorder
Can you Help with these Camcorders problems?
Tape jam on Sony Handycam
Are you aware of a release... Answer This...
canon optura 20 wont eject
i have a canon optura 20 and on... Answer This...
Canon ZR 10 not...
I've replaced the cable and the... Answer This...
Canon ZR10 mini camcorder not...
No image shows in viewfinder... Answer This...
Cassette tray will not eject
My brother recently gave me his... Answer This...
Repair Service
Find Camcorder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
