Question about Lite On Televison & Video
I have a LVC-9016 combo..It does not record now..will give a protected content response regardless of disc.
  • Lite On Master
  • 19,396 Answers
Try unplugging power cord for ten or fifteen minutes, if this does not help try using a cleaner CD.
Posted on Sep 11, 2008
  • Ginko
    Ginko Sep 11, 2008
    Try first unplugging power cordfor a while (turning off it is not enough). This will drain power from the circuit s and can fix some problem.
    If it did not help try using a lens cleaner CD, often when lens is dirty the DVD does not recognise the disk and can return a protection error of this kind when it tries to write.
    Here you find DVD lens cleaners.
    Try also using a different kind of dvds, often a DVD RW does not work well with a particular DVD brand or type.
    Try with one DVD +R and one DVD -R, possibly try good brand one (TDK, Philips, Verbatim etc.) if it works on one of the two DVDs, it means your unit had developed a problem on one of the two DVD types. This is due to the different correction error used by the two formats, and usually is also a lens related problem.
    If DVD lens cleaner did not work, you can only clean the lens taking apart the DVD. Access the lens pickup and clean the lens with an extra soft cotton stick and isopropyl alcohol.
    Regards
  • Ginko
    Ginko Sep 11, 2008
    I forgot to mention that in rare case this problem can be result of a bad firmware, in this case you sort it out with a firmware update, if firmware is available.
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Need an user manual for lvc-9016
You can get a manual for lvc-9016G from;
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=75
These files appear to be in ZIP compressed format so you will need to un-zip them with your ZIP program.
If you need the ADOBE reader you can get it form www.getadobe.com
Apr 29, 2011 | Televison & Video
Lite on lvc 9016g does not prepare disk
Mine does the same thing. If you get the fix email it to me.
Jan 22, 2010 | Lite On LVC-9016G DVD Recorder/VCR
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
Nov 20, 2007 | Lite On LVC-9016G DVD Recorder/VCR
Lite on lvc 9016g will not prepare dvds or record
I have solved my problem with the LVC-9016G. I used OptiDisc
Laser Lens Cleaner for dvd Players. Both my units work fine now, with several different type of Discs. Hope this helps.
Oct 23, 2007 | Lite On LVC-9016G DVD Recorder/VCR
Televison & Video Logo
107 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
