SOURCE: Laptop can't find router
did the d link come with a cd if so run the cd in your lap top. then configer from there but if it doesnt work you might have to buy a wireless card for your laptop i dont know if they put a internal card in the hp dv6000 they should have with running vista
thanks
hope this works for you
SOURCE: lost installation cd for d link DIR 300 wireless G router
Most routers don't require discs and the disc usually contains mere documentation for configuration and help. Routers are usually plug-and-play type devices but if you're definitely wanting some type of program or information. You can visit the below link for your router.
http://www.dlink.com/products/support.asp?pid=474&sec=0#applications
You'll need to specify by clicking the "Click Here" based on the revision of your router (A, B, or D). Once you've selected a revision, you'll be able to download the application and firmware updates for your router.
SOURCE: how do i block some sites on d-link dir-615
Go to this link. http://static.tigerdirect.com/pdf/D-Link-DIR-615-Manual.pdf
On Page 31 you will see how to filter websites. Let me know if you need any other clarity.
SOURCE: how to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
SOURCE: Hi, I'm trying to reconfigure my
You will need to be hard wired (you can't configure a router via a wireless connection...
For default IP use 192.168.0.1 and the default user name is "user" password is .
that should get you in.
