Question about Brother SX-4000 Typewriter
Carriage stopper I believe the carriage stopper fell off. How do I put it back on? It doesn't look like anything is broken.
    Scholar:
  • 183 Answers
The printhead is the part that moves back and forth. It is stopped electronically. There are no "stops" per se. What does the part look like? If everything works properly, it could be a forien object, that is, something that was not actually part of the machine.
Posted on Oct 25, 2008
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
Window fell off track on driver side door
Remove the inner door panel and check out the problem
I don't think it fell off anything
I believe you will find a broken window regulator
Feb 03, 2011 | 2002 Mercury Mountaineer
My husband fell into the television and the front screen popped out. Can we put it back in ourselves? It is not broken
You should be able too. You will need a torx #20 driver bit to remove the bezel around the screen. Carefully... The screen can be easly scratched
Oct 22, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Stopper has dislodged.
Hello. It is probably not broken. In order to fix it, you must go under the sink and above the trap. You will see where the lever for the stopper is attached and can be adjusted. If necessary look under another working sink with a similar set up. Joe
Apr 15, 2010 | Kohler Caxton Undercounter Lavatory Sink...
Black Circle With The Bose Name Fell Off
take the cloth off the speakers take out the speakes there are two screws top and bottom. remove speaker. be carefull not to rip the leads wire off of the leads. you should see three screws they hold the bose symbol in place just align the bose symbol and scew the screws down.
Jan 06, 2010 | Bose TriPort Consumer Headphones
Clear carrier jam is error message
Not that difficult check if behind the carriage(part holding cartridges) has broken off.Its a small plastic latch about 3 inches in length.
If not then try moving the carriage manually with your hand and see if it moves if it doesn't press and hold the power button and while holding the buttons unplug and re-plug the power cable to the printer .Clean the carriage rod with alcohol on a cotton swab/lint free cloth and then see if the problem surfaces if it does then its time to get a new printer
May 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Need Help putting the bobbin case back in the futura ce 100?????
With the needleplate removed, locate the black plastic bobbin case in horizontal and level position with the "bull horn" facing the rear, so the needle has space to move....
Gently place finger on top edge and move bobbin case, there ought to be a small amount of movement (1 or 2 mm slack) to allow passage of thread past the stopper spring (at front right)
If there is no slack at this position, have you adjusted anything to "tighten it up a bit", if so, relax the stopper spring by an "almost nothing" amount (again, 1 - 2 mm) to allow the thread to form the stitch.
....if you have had some needle strikes and damaged the surface, fine emery paper may be used to smooth the damage, if significantly scored, replace the bobbin case.
Feb 18, 2008 | Singer CE-100 Futura Computerized Sewing...
Sharp ux b700
check carriage home postion sensor(often in your left hand near left end of the machine-check for a broken connector and reconnect it-check for droped object or dirty in the sensor.
Jan 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Buttonholes
Can you do an ordinary reverse stitch, if not, the reverse mechanism may be jammed, that will need some further internal exploration,
BUT, if you can, then:
The sensor arm that pulls down from the machine needs to be between the carriage stoppers, this tells the machine how large the button is, therefore, when to change direction.
The Kenmore is similar (same?) as Janome I believe and so should be very similar to this image.
Ensure that the sensor arm is pulled down between these two plastic stoppers at points maked with red, if the arm is at the rear of stopper, it will not do the cycle, just continue.
Only reset the machine after each completed buttonhole, if reset in mid cycle you will be starting a new cycle before it is time.
Do a couple of tests on some scrap fabric before you commit.
Bargain Box
Jan 28, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Brother SX-4000 Typewriter Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
