When you turn the tv on you get the sound, but nothing comes on for the picture. Usually you can bump the bottom of the tv by the buttons a few times, and it will come on. Whats going on?
ok you must go to the Horzontal drive curcuit and remove a small coil called L401.. Scrap off the leads, reinstall and resolder. all your troubles will be gone. also for giggles resolder the horz drive transformer as well. also you may need to dom a tuner mod as toi resolder the sheilds around the tuner as well as the grounds inside under the bottom tuner cover. Good Luck
This usually a problem on/near the horizontal section of the TV board caused by solder that losses its contact thats why you need to bump it sometimes for the picture to come out. To remedy this just try to resolder any parts that you suspect seems to loose especially in the part where the components tends to get hot when operating, this usually are the horizontal section or the power supply section which is very common.
Sometimes when I turn the TV on and try to watch anything that goes thru the coax connector I get...
(More)
Sometimes when I turn the TV on and try to watch anything that goes thru the coax connector I get noise and no picture and sometimes it will clear when you turn off TV and then turn it back on some times not. The signals thru the S-Video and RCA cables have no problem. This problem is got to be easy enough to fix if I knew what to change. Is this a tuner or filter problem I dont want to replace TV it still works otherwise.
since digital change-over even with the cable line connected, I just get a fuzzy picture and sound,...
(More)
since digital change-over even with the cable line connected, I just get a fuzzy picture and sound, but all my other TVs of different brands work just fine. Can you tell me what to do?
Is there any way to deactivate the sound leveler on an RCA 27V520T? It ruins the ambiance of my...
(More)
Is there any way to deactivate the sound leveler on an RCA 27V520T? It ruins the ambiance of my videogames and movies by muffling explosions and gunshots, and it's not working on the commercials, which pretty well defeats the purpose.
