Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
What does it mean when the screen shrinks up to about 5 inches in the middle of the screen?
  • Philips Master
  • 3,459 Answers
If it shrinks and then expands over and over you can get a repair kit from www.TvRepairKits.com
Posted on Jan 11, 2009
  • 4,234 Answers
Usually this is a bad cap in the vertical circuit or a failure of hte vetical IC. If you can post the make and model number, I should be able to provide you with more details.
Thanks,
Dan
Posted on Sep 10, 2008
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Shrinking screen
check the user manual also can be misconfigured or check the source voltages and convergence
Sep 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My sirius car antenna cable got cut by the trunk closing on it. I tried connecting the two ends and the system can not get a signal. What can I do?
Small heat gun.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 07, 2009 | Sirius Satellite Radio Receiver
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
Screen shrinking
You have bad solder connections on the vertical output IC or on one or more of the surrounding components. Good Luck
Jul 21, 2007 | Toshiba 36A40 36" TV
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
