Question about Mirage LF100 Subwoofer
Fuse blowing out
Mirage LF100 issue. Fuse is blowing out, Conncetions look fine, it powers up, but then blows out.
  • clbergeron Oct 27, 2008
    I have the exact same problem. I keep replacing the fuse and it keeps blowing them right after i power the subwoofer on.
  • 682 Answers
You must check your cables first and try witth anoher cables if the problem remained you will have internal problem inside and needs to fix in service center
Posted on Sep 10, 2008
Issue of fuse constantly blowing.
Is the fuse correct amperage rating. There is to much power going to fuse. If it is the correct fuse you have a short most likely ? wire touching metal. The power lose is because this is main fuse.
Nov 02, 2015 | 1997 Toyota Camry
97mits mirage 1.5 blows 30amp fuse as soon as ignition key hits turnover position? Suspect bad ground
Try disconnecting the wires from the starter and try it again. If it blows the fuse again, then your ignition switch it'self is probably shorted. If it doesn't blow the fuse, your starter is grounded on the inside and needs to be replaced.
Nov 09, 2014 | Cars & Trucks
Terrano vg30e electrical issue...
first thing to do is to have the alternator checked out as the fuse blowing may indicate an internal short and therefore the battery is not being charged ( 3 starts and needs a jump)
Dec 05, 2013 | Cars & Trucks
Tail lights and dash lights out, fuse keeps blowing
a fuse burning is due to a short in the circuit ( something is grounding out before the load). the load is the light. heavy amperage draw will blow a fuse, but assuming you didnt wire up 4 big off road lights or a winch to that circuit, its most likely a short.
Nov 11, 2013 | 1995 Mitsubishi Mirage
Power washer works perfect for 10- 15 minutes then blows fuse. Put in new fuse straight away and works fine again for another 10-15 minutes.
These machines can have issues such as you have explained if they are run off from an extension cord or if they are really far from the breaker box. They have this issue because the amount of amps that are going to the machine aren't enough for the motor to operate efficentially so the motor in turn gets hot and blows the fuse or the breaker.
Another issue could be is that the nozzle is being restricted to much and is causing the motor to work harder than what it should and is causing the machine to over heat. This in turn would cause the motor to blow a fuse or a breaker.
Oct 30, 2010 | Karcher 1750 psi Electric Pressure Washer
Have charged the battery on my 1999mitsubishi mirage
you may connecting it wrongly , please check +ve and-ve both pole are to be fix with proper wire, if will do wrong it will blow fuse.
Jan 31, 2010 | 1997 Mitsubishi Mirage
When i turn on the A/C the fuse blows. I tried a
A bigger fuse can burn things, be careful.
You have an amp draw bigger than the fuse can take, that's why it blows, and the clutch on the compressor for the A/C may be your culprit. If you can unplug the wiring to the compressor, replace the fuse with the correct one, and see if it fails then.
Jul 10, 2009 | 1999 Mitsubishi Mirage
Hooking up my Digital audio subwoofers
How did you connect it to your receiver?
Jun 14, 2009 | Mirage LF100 Subwoofer
98 Mirage Stuck in Limp Mode
You may not need a new TCM with any luck. I would try unhooking the battery for a few minutes to see if it will reset the TCM.
TCM = They Cost Much $. If you need to replace it you should be able to get one at a local parts house - avoid the dealership if you can. I wouldn't trust on-line stuff for this unless you know the source.
Jan 15, 2009 | 1998 Mitsubishi Mirage
Mirage LF100 Subwoofer Logo
321 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
