Do I need to hook a separate telephone wire to the copier/fax machine in order to send fax or will it go thru my dsl line?Do I need to hook a separate telephone wire to the copier/fax machine in order to send fax or will it go thru my dsl line?
AnonymousDec 04, 2008
I can not send a faxI can not send a fax
WILL NOT ACCEPT FAX
IT WILL SEND FAXWILL NOT ACCEPT FAX
IT WILL SEND FAX
both the numbers should be same otherwise the fax machine will not work properly ..............you have to ask the person who gave this machine for a change of number
that's is a driver issue.. you need to uninstall your current printer driver and then restart your computer .. and then install it again,,, because your scanner application has been corrupt..
If you only use this line for a fax the least stressful option is a fax to email service and re-direct the incomming calls.
If you use this line for fax and phone do as I suggest above except re-directing the calls but dont forget to tell those who fax you of your new number
fax machine won't let us receive faxes
I'm trying to send a fax and I can't quick get it.
WILL NOT ACCEPT FAX
IT WILL SEND FAX
my fax says remote fax error
I can not send or receive fax
I need help
thank you
