Question about Sony Televison & Video
Sony Plasma problem - blackouts
I've had a Sony Plasma TV for just under a year, and a few days ago it started going out on me. It's connected to a DVR box, and every 1-10 seconds, the screen goes black. The sound is not interrupted and the power does not actually shut off, it's just the picture that is affected. The TV is connected to a DVR box and has external speakers. Do you know what could be causing this and if it can be fixed easily?
  • bcarimi1 Sep 10, 2008
    Thanks for the quick response! The model # on my owner's manual is FWD-42PV1/42PV1P/42PV1A
  • 10,594 Answers
What is the model number of your Sony TV?
Posted on Sep 10, 2008
  • Shahid Electronics
    Shahid Electronics Sep 10, 2008
    Model number would be PFM-42V1 and please try to check its performance on dvd player as well because problem can be exist in dvr box too. Kindly let me know does tv function ok on dvd player?
Green lines vertical on lg 50 plasma tv started with one thin one week or two later developed another one what can i do to fix the problem
I had the same problem with a Sony tv a couple of years ago. The cable connection was going through the VCR, then to the tv, so we thought we could try making a direct connnection, and the lines went away! I'm not sure if this is your problem, but if so, this should do the trick. If not, call a repairman, and they may be able to help.
May 29, 2011 | LG 50PX1D 50 in. Plasma Television
Their was a blackout in my neighborhood. The next day in the morning i tried to turn on my 50inch HP Plasma and it made a loud popping sound. The volume on the tv still works.
Hello.
You probably did not have that tv plugged into a surge protector. When the power was restored, a surge came through the line. A power surge is a spike in voltage above the maximum a tv, appliance etc. can handle of 169 volts. They are very brief, usually lasting millinths of a second. Power surges can vary in duration and magnitude, varying from a few hundred volts to several thousand volts.
That said, now what do you do. If the tv is under 3 years old I recommend that you take it into a local TV repair shop for a free estimate of repair. If it is older than that, I would not repair, just replace. J.
Sep 12, 2010 | HP Televison & Video
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Dec 29, 2008 | Yamaha RX-V1700 Receiver
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Blackout screens
Good Day;
I would suspect U-VERSE. I had it installed recently ...had problems. They came out and changed "wires". Now okay. Please call them first. Good Luck, big IRISH.
Aug 14, 2008 | Hitachi 43UWX10B 43" Rear Projection...
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Televison & Video Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
