SOURCE: jammed steering lock
Move the steering left and right while turning the key. If any pressure is on the lock pin then the pin can't slide freely. With pressure on the lock pin the key will feel like it will not turn to unlock.
Hope this helps. Please rate this solution. Thanks
SOURCE: e39 starting issues
HAVE YOU HAD THE BATTERY TESTED? ARE THE BATTERY TERMINALS/CABLES CLEAN AND FREE OF CORROSION? ARE THEY TIGHT?
SOURCE: E36 BMW 318I CENTRAL LOCKING
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
SOURCE: 1998 BMW 528i won't start. not even clicking from the starter!
Worse case senario.The computer has been blowen from the jump starting.It is common if the jump starting proceedure is not followed.
SOURCE: bmw 1 series wont start
my bm 1series came to a shudder a code came up p0012 got the actuator cam. from main dealer fixed still wont start
