Question about X-Gaming X-Arcade PC Joystick (XGMPC)
I have a 1983 popeye arcade machine. the circut board that controls the vert hold for the monitor has 4 knobs for vert., sound, horiz., and bright. thevert. hold knob is busted off and the screen has just a thin red line that runs across it when the game is on. how can i fix this?
  • 13 Answers
If this is a Sanyo EZV20 monitor, then the vertical hold knob is a 200K ohm pot. FYI the other knobs on this PCB are, Volume - 50K, Brightness - 10K, Horiz Center - 100K, Vertical Size - 50K. For the schematic, check out my web site:
http://arcadeconnection.serverbox.org/arcade%20machines/english/schematics/Sanyo%20EZV%2020%20(R-C)%20Monitor%20[Schematics]%20(EN).pdf
Posted on Sep 21, 2009
    Problem Solver:
  • 6 Answers
VR353 is a 200k pot that feeds directly in to the vertical oscillation input of the chip on the main board at connection B1. If this pot is broken, you must replace the pot in order to get any vertical oscillation at all.
Posted on Aug 16, 2009
My 140express hasn't spun properly an is showing the sign F21
It sounds like a problem with the control board. To reset the codes follow these instructions:
1. Close the door.
2. Turn the knob to 6 o'clock position.
3. Wait 2 seconds.
The start/pause should begin flashing.
4. Press and hold the spin button.
5. Turn the knob to 7 o'clock position.
Wait 2 seconds.
6. Release the button.
7. Turn the knob to off.
This should erase the error code and get you running again.
If the error code returns, you have a problem with the motor, wiring or main control.
If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
Try it several times to see if you get it reset.
Hope this helps.
Bob
Jan 03, 2015 | Bosch Washing Machines
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Golden tee black screen
Are you able to advise some more detail for this issue please?
Can you play the game 'blind', which means coin it up, start a game and hear the game making normal gameplay sounds? If so this shows there is an issue with the monitor, or the wiring to the monitor.
Are there any lights lit up on the main game board inside the cabinet? If so this also shows there is an issue with the monitor, or the wiring to the monitor.
Is there any neck glow on the monitor tube, which is the back of the tube itself where it narrows down like a funnel to a narrow glass tube? If so this would indicate the monitor is most likely functioning and could be a game board issue.
You can also determine whether a monitor is functioning by turning up the brightness to full using the brightness potentiometer on the monitor chassis, or the potentiometer on the flyback transformer. The flyback transformer is the plastic looking device that the high tension lead comes out of and connects to the monitor tube, a lot like a spark plug lead connects from the cars distributor cap or coil pack to the spark plugs. It should show a lighter screen and probably with lines in it if the monitor is running.
Jan 24, 2014 | Arcade Golden Tee Unplugged Video Cabinet
Need Horiz button help on Mitsubishi 45" TV...easy fix?
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Oct 20, 2009 | Mitsubishi VS-4544 45" TV
Adjusting brightess on monitor
take the cover off the monitor and adjust the screw on the fly back to adjust the brightness it will be in the shape of a little knob
Apr 16, 2009 | Mr. Coffee HCLF
Convergence problem
most likely u have to change the convergance ic's that is the first thing u do and it should work if u are not loosing any vert or horiz drive going to your convergence ic now there is one other thing that the have on the bigscreens if it is a magnavox they take the horiz drive from the if board it has a mirco chip on it that seends the horiz blanking p to the convergence board. hope this will hp
Sep 06, 2008 | Philips 55PP9401 55" Rear Projection...
Horizontal/Vertical Postion of Image on LCD Monitor
the controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Apr 25, 2008 | Gateway FPD2275W LCD Monitor
Mistubishi tv vertical hold not working
you can go to this link and one of thier tecs can help you out just leave them an e-mail with your model number and they kow how to do the bypass
Apr 10, 2008 | RCA D52W19 52" Rear Projection Television
Zenith monitor in an arcade game
Check to see if you can find horizontal and vertical sync controls. These would typically be small knobs or screwdriver adjustments on the edge of a circuit board or at the back of the monitor chassis. Try adjusting the vertical sync....rotate the knob back and forth two or three times to "clean" it...then adjust to see if you can get the picture to settle down.
Aging electrolytic capacitors are the most common cause of symptoms like this. You'll need the assistance of an experienced electronics technician to find the exact source of the problem.
Jan 16, 2008 | Gateway FPD2275W LCD Monitor
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Video Game Consoles & Games Logo
123 people viewed this question
Top X-Gaming Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a X-Gaming Video Game Console and Game Expert? Answer questions, earn points and help others
