Question about Safety 1st Acella LX Winnie the Pooh Standard Stroller
I left the batteries in my Graco swing when I had my last child 4 years ago and now it is rusted, is there a way I can fix this or a replacement part I can order?
    Brigadier General:
  • 5,158 Answers
Baking soda and a water solution.... perhaps use perhaps a q-tip to apply the solution... do not pour it into the item..... just carefully use the q-tip to wipe the inside of the battery case. i would even suggest holding it upside down so that liquid does not leak into the device.... allow it to dry ... insert the batteries and test it out.
I would suggest (because it is near a child) to dispose of the item and purchase another one as that rust is partly battery acid.
Robert
Posted on Sep 10, 2008
Graco swing
I'm not sure if you tried a different outlet plug yet, but I would try to eliminate whether if its the power source (outlet) or the swing itself. Also, if the outlet has a reset/test buttons on it, then it might have tripped itself.
Apr 23, 2013 | Baby Care
I have a new graco cleo car seat. What weight and age does my baby have to be before I shoud face it forward in the car?
Group 0 Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, whilst perfectly supporting your child's back.
Group 0+ Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, while perfectly supporting your child's back.
Group 0+/1 Children are unique and grow at different paces so category 0+/1 seats are highly flexible to reflect this. Babies up to 9kg (19 lbs) can travel safely facing the rear. From 18kg (39lbs) the seat can be adjusted so they face forward, allowing you to spend more time face-to-face with your baby which is an important part of parent-child bonding.
return to top
Group 1/2/3 The car seats in this category grow with your child from 9 months to 12-years old (9-36kg/19-79 lbs) so they can remain comfortable and importantly, develop properly. This flexibility makes it the ideal car seat category for large families and grandparents with grandchildren of different ages.
Group 2/3 A child must have a car seat that is tailored to their weight, height and age until they are 12 years-old, or 36kg (79lbs). The group 2/3 category offers convertible seats for older children aged between 4 and 12 (15-36kg/33-79lbs), this means the car seat grows with your child.
Hope this helps, I have a graco for my 12 week old, this info is from the graco website
Bye for now
Aug 04, 2011 | Graco Baby Gear
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco lite rider navigator SL stroller broken seat holder clip
I've got a navigotor stroller and I can't unlock the back wheel brake or fold it
Dec 09, 2009 | Graco LiteRider 6712SFT Stroller
I'm reusing my daughters GRACO crib for our next child and i lost the instructions on how to put it together. Do you kinow where I can find instructions? We bought the crib about 5 years ago. Its a 3 in 1...
The Aspen 3in1 crib along with millions of other drop-side cribs has been recalled.
Here is the CPSP link reguarding this crib:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
According to the CPSP information the company appears to be out of business to some degree and are not providing repair kits.
If you know where you purchased the crib, check to see what their policy is reguarding recalled baby products.
We had purchased ours at walmart almost 8 years ago and were able to return it to another store in a different state for a full refund last summer. They did not need a reciept received, they just needed the manufacturer label on the part that the mattress lies on.
Because ours was older, the customer service clerk did have to work hard to find the crip in their system, but once she did, it was not problem at all.
Nov 27, 2009 | Graco Apsen 3-in-1 8740 Crib
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Nov 15, 2009 | Graco Baby Gear
Safety 1st Acella LX Winnie the Pooh Standard Stroller Logo
141 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
