Question about Frigidaire Washing Machines
I have a Frigidaire LTF2140ES1 Washer and it will not go into the high speed spin. Error code E43 (Replace Control Module) Module has been replaced. Ran the Diagnostic test and still get error code E43 at the end.
  • Frigidaire Master
  • 1,527 Answers
Hello doug just looked a error code e43 board communication problem
shaun
Posted on Jan 16, 2009
  • 3 Answers
I have this same model. The control panel is locked and the washer will not run at all. HELP !!
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
Jul 11, 2015 | Frigidaire 131763202 WASHER DOOR LOCK...
E43 code on atf6000eso washer
Thanks for your post, friend!
Based off the error code you were able to provide your Frigidaire washer is providing you're an "E43" error code and that means your control panel needs to be replaced. This is not a simple DIY job and I would highly recommend reaching out to an expert technician to ensure the replacement part is installed correctly to prevent future issues. I hope this information helps to some degree. -Matt
Oct 09, 2014 | Frigidaire Washing Machines
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Washing Machines Logo
1,014 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
