Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Continues rebooting I'm using Vista Home Premium on my laptop. My laptop will go to blue screen and prompt me "a problem has been detected and windows has been shut down to prevent damage to your computer" It then will prompt me with an error string. Examples; Page_fault_in_nopaged_area, Maximum_wait_objects_exceeded, No_more_IRP_stack_locations, Bad_pool_header, and etc. Everytime it tries to reboot it comes up with a blue screen and a different error. Is there any thing I can do?
  • Dana Scott Sep 17, 2008
    I'm receiving multiple stop errors every time it reboots;
    page fault in nonpaged area Stop: 0x00000050 (0x00000000, 0x804050fb, 0x00000008,0xc00000000)
    Bad Pool header 19 ( same , 0x8cee3878, same , same )
    No more IRP stack locations 35
    IRQL not less or equal A0
    Bad driver 99
    Etc...........
    The stop ID and parameter 2 are the only different numbers for the stop errors. All other parameters are the same. I am currently receiving a list of 10 stop messages/codes and the software will continue to prompt" restarting". It starts to boot up and another error appears. I have to shutdown/ restart the laptop to get out of this loop. Usually this doesn't occur until approx. 20 minutes of the laptop being on. Sometime it runs several hours without a problem. Could it be the hard drive? I
  • froggus May 11, 2010
    A "Blue Screen Of Death" (BSOD) usually indicates a problem with the hardware or a bad driver, most often the RAM or hard disk. It results in a stop error which takes the form:
    STOP 0x000000?? (parameter1, parameter2, parameter3, parameter4)
    Can you post this stop error?
  • 3 Answers
OK it is going to be difficult to solve this one with so many different errors. Given that this is windows Vista it is probably a bad driver. Possibly the graphics card driver. Also vista is quite punishing on hard disks so we'll start there.
First off take a backup of all your documents photos videos etc. because the check disk can cause havoc if it finds a lot of errors and can take down windows altogether. Also you must be prepared to re-install windows so make sure you have a recovery method (recovery CD's or a hidden partition on the Hard Disk) If the hard disk is truly borked though it might take the hidden partition with it. Proceed with caution and make sure you can get the PC back up and running if the worst happens.
First run a check disk. In My Computer, right click on the c drive, click on properties - tools - check drive for errors, then restart your computer and let the chkdsk run.
Post back here with the outcome.
Posted on Sep 18, 2008
Recover to factory condition windows vista
To use this feature put the original windows disk into your pc/laptop and reboot. As soon as the reboot starts starts pressing F12. Choose the menu option that allows you to boot from a CD. VISTA will start and in the next few screens allow you to install to the original factory conditions.
Dec 25, 2013 | Microsoft Windows Vista Home Premium with...
Received a blue crash screen, Alt,F10 for erecovery, showed copying files, then tried to reboot and shut down without completing reboot. Now when try to start, showes windows small window and moving dots...
You can use a torrent site like isoHUNT, to download a copy of the Acer OEM vista disc, this is a little illegal, but if you use your own Windows key from your COA sticker, it should register and activate ok.
You may have to download your drivers seperatly from from ACER.
You will need a torrent client like UTorrent, and the download could take a day or so
Aug 27, 2010 | Acer Aspire 5100 Notebook
Blue screen of death
upon restarting keep pressing the F8 key to get into the repair screen
choose the command line with the c:/ prompt
when that appears type in chkdsk /f /r and press enter
choose Y to perform this task then log off and reboot
chkdsk will run and check for any problems in the registry and repairs them
Aug 02, 2010 | Microsoft Windows Vista Home Premium...
Blue line down monitor screen of laptop, initially. Occasionally there are two blue lines and two blue and a red one.
either the screen is damaged or the convertor is faulty. Suggest drop into local repair shop. If extra lines come aftre extended use then likely to be the convertor at fault
May 25, 2010 | Microsoft Windows Vista Home Premium...
My Vista PC stopped seeing my SD, CF, etc. drives. It still sees my blueray. All are built in. This happened before and I fixed it by downloading new drivers from MS, but I can't find the drivers now.
I would try uninstalling the device(s) using Device Manager and immediately rebooting the PC. Upon reboot, Vista will detect the hardware and install all their drivers.
Oct 04, 2009 | Microsoft Windows Vista Home Premium with...
Click on icons of user accounts on startup and Nothing Happens!
There are Spyware/malware resulting to this kind of behavior. You can remove your System Disk to another system that have antispiware up-to-date database. Kaspersky or AVG Internet Security are very effective.
Or else Im afraid you will need to format you OS drive to eradicate virus and malwares and reinstall the OS
Jan 24, 2009 | Microsoft Windows Vista Home Premium with...
Blue screen error on windows vista home premium 64 bit
Without the error code, I will address the 'BSOD' in general here. Normally, this will happen when there is a driver fault with one (or more) of your hardware. Have you recently installed software? Older versions of programs that are not Vista approved will also cause this.
Will your computer start in Safe Mode?
You can also do a Repair of Vista using the System Recovery Options. (Choose the "Repair" option when prompted - this will tell you what is actually causing the Blue Screen.
Here is a complete 'how-to' on using the System Recovery:
http://windowshelp.microsoft.com/windows/en-US/help/2b3724d1-f4ad-5b26-16dc-3e9e66f4be5e1033.mspx
Jul 24, 2008 | Computers & Internet
Instalation problum
PLEASE CHECK THE PRODUCT WILL SUPPORT FOR WINDOWS VISTA BECAUSE SOME PRODUCT WILL NOT SUPPORT FOR WINDOWS VISTA ...PLEASE DOWNLOAD DRIVERS FOR SUPPORTING WINDOWS VISTA...
Apr 30, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
268 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
