Question about Dishwashers
Water standing the is water standing in the dishwasher when its done.
  • lbarnell Sep 10, 2008
    i have a kenmore model#665 15669990
    There is always water satanding in the bottom when the cycle is done.
    It never drains all the way out so the dishes are not getting clean.
    Novelist:
  • 166 Answers
Heool Isharpbailbo,
ngfam1 At your service!
Sounds like it may be one of a few problems,
1.The drain may be clogged going out to your kitchen sink
2.There may be some food or debris at the bottom of the inside of the dishwasher blocking the drain screen. BE CAREFUL RUNNING YOUR FINGERS DOWN IN THE BOTTOM OF TH WATER!
There may be broken glass in there that you can not see through the water , holding back food causing the blockage!
I cut my finger once clearing this to quickly.
3- you may have a bad pump that may need to be replaced.
USUALLY its a blockage some where from the dishwasher to the drain.
I once saw a large piece of broken glass in the drain holding the food particles back.
That's the on that got me so move your fingers real slowly in there , if you must use your hands.
I recommend hands on service if it's a fairly new machine!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN O
Posted on Sep 10, 2008
Dishwasher tablet always in bottom of dishwasher
Question : has it always done this?? is it hooked up to the hot water and is the water HOT !!! 140-145 degrees
Dec 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Brand new dishwasher, installed last week. When it is done there is quite a lot of water standing in the bottom of the tub. It has only been run 2 times since installed and both times several inches of...
First was a new garbage disposal also installed? There is a knockout on the garbage disposal where the drain hose connects to.
If that is not the problem make sure it has the correct high loop or also called air gap. If that is not right water can siphon back into the dishwasher. Both are common mistakes usually made by begginers. Here is a link for the correct High loop installation
Oct 26, 2010 | KitchenAid KUDC03IVWH Builtin Dishwasher
After the wash, the water still remain in the basket.
IF you still have water standing in your dishwasher after it's done running you most likely have a damaged pump. This is quite common and is usually caused by a piece of a broken dish/glass or a small utensil getting down into the pump and breaking the fins on the empeller. This is a fairly envolved repair that requires taking apart the pump in order to repair it.
Jul 29, 2010 | Asko 24 in. D3121XL Free-standing...
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Water leaking on floor from dishwasher
get it looked at or pull doors off and drawers pain in the *** if you havent done it
Apr 22, 2010 | Fisher and Paykel 23 in. DD603H SS...
The water stands in the bottom of the dishwasher after the cycle is done
just wring out the standing water with paper towels into your coffee mug
Feb 26, 2010 | Dishwashers
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Indesit 24 in. DI67
Hi there
I have had this problem before. If your dishwasher is not level water collects at the front. Try tilting your machine forwards. Be carefull though as water will come out of the bottom. Once you have done this and reset your machine it should be ok.
Jan 12, 2008 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
145 people viewed this question
Top Dishwashers Experts
