Question about Weber Genesis Silver A Grill
Weber Grill, Genesis Silver A Burner Replacement Instructions
My burners are not working correctly and only portions will light up when cooking. I have found a source for new burners and flavorizer bars, but I am looking for instructions on the removal and replacement of the burners. Can you help me or give me another place where these may be available?
Thanks for your inquiry. In checking around, new parts will cost me $45- $50, plus your fees for instructions and several hours of my time. I checked prices at Home Depot today and have decided just to buy a new grill and enjoy it without all the mess.
Stu
Posted on Sep 11, 2008
I think I need a new crossover ignition system for a Genesis 320 natural gas grill, where can I get one? I cannot find the correct one on your website.
Nancy, we don't have any parts on the FixYa website. But, if you're referring to to the crossover burner, that lights the last burner, you can find it at the following link under "tubing". http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/weber-tubing.html
Hope this helps you and Happy Grilling. Thanks for choosing FixYa.
Aug 02, 2011 | Weber Genesis Silver B Grill
Weber grill one row of burner does not light
A clogged burner possible caused by an insect nest, or the pathway is disrupted for the pilot flame to travel to the next burner, or stopped up or face.
Apr 03, 2011 | Weber Genesis Silver A Grill
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Aug 06, 2010 | Weber Genesis Silver B Grill
It takes a very long time to cook anything on the weber grill. it never gets really hot. The grill is about six years old. What do I do to correct this problem?
check for rust/debris on the nozzles (these are small screws with single hole in them inside of the burner, clean the burner, dissassembly and clean the valves on the grill NOT ON THE BOTTLE!
this should solve the problem, alternatively, if burner was not used for long time, regulator maybe stuck in this position and will need replacement.
Jul 15, 2010 | Weber Genesis Silver A Grill
Two burners run too hot with yellow flame.
It sound like your back burners have a partial blockage or possibly are rusting or falling apart or have cracked seams. Remove the cooking grids and burner shields, and examine the burners closely. If you can't find a blockage inside (spider web, bugs nest, etc) then their condition is probably deteriorating. Let us know if you need more assistance.
May 21, 2010 | Weber Genesis Silver B Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Weber Silver B grill
I bet your grill gets no hotter than about 300 with the lid closed?
The tank has a built in safety feature. If a burner is left on when you open the valve on the tank, or turned on too soon immediately after opening the valve on the tank, the flow will be restricted. You need to turn all burners off, close the tank valve, disconnect the tank, reconnect the tank, open the tank valve, waqit a few seconds, open the burner valve and light. You'll get unrestricted flow and much better heat.
Oct 31, 2008 | Weber Genesis Silver B Grill
Weber Genesis Silver A Grill Logo
1,251 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
