Question about Vivitar V4000 50MM 35mm SLR Camera
Film = no light meter
When no film is loaded into my Vivitar V4000, the light meter seems to function fine. When I load film into the camera, there is no more light meter. I have changed the batteries. Is there anything else I can do on my own short of taking it in for repairs?
    Scholar:
  • 185 Answers
Jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Posted on Dec 15, 2008
What Film Should I use for Vivitar V4000?
try Kodak ISO, ( ASA), 400 ( DIN 27 Degree ) 35 mm film to start. if you like the results, stick with it. remember the faster the film the higher the grain. the slower the film the finer the grain, sharper enlargments with finer grain.
Jun 07, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Light meter on my vivitar v335 ( film) doesnt show up
If there is supposed to be one in the camera, you may need to install/replace a battery.
May 29, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Loading film into the vivitar camera binouclurs
you have to pull up on the film rewind knob(pretty hard) and the back of the camera pops open. on the left side is where the film goes attach the piece of film to the film take up spool.
Jan 12, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
How do you open te Vivtar V4000?
I have used left/right as if you are holding the camera ready to take pictures.
I have included the instructions to rewind the finished film.
!/ Press and hold the film rewind button button on the right side of the camera base.
2/ Fold out the rewind crank top left of camera and turn it in the direction of the arrow.
3/ Once the pressure eases, the film is completely wound into the cassette.
4/ Lift up the film rewind knob top left of camera and pull it out to open the back cover. Now the film cassette can be taken out.
5/ Do this in a place away from direct sunlight.
Jan 05, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Can't load film into vivitar pZ 8000 camera?
Most probably find a Vivitar Vivicam PZ8000 manual here. Just send them a search request. Service is not free, but often worthy.
Oct 14, 2008 | Vivitar PZ 8000 35mm Point and Shoot...
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Load film into my camera
I need a copy of the instuction manual fo the Vivitar Vivi Cam 35 Digital Camea
Jan 21, 2008 | Vivitar ViviCam 35 Digital Camera
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Vivitar V4000 50MM 35mm SLR Camera Logo
282 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
