Question about LG WM2688HWM TROMM SteamWasher
Laundry Detergent not being added
I put laundry deterganet in the blue cup and all of a sudden it's not goingg into the washer..it will go throught the entire washing cycle just fine but, when I open the door to put detergent into it..the detergent from the previous load is still there which means my clothes are'nt getting clean....I have had this pair for 2 years this christmas..anyone know what's wrong and how I can fix it?
  • Anonymous Sep 10, 2008
    Just bought a GE front load model #WCVH6400J and after the first load the soap dispenser is not emptying. I am using the HE detergent.
  • 489 Answers
You will need to have a qualified LG technician come and diagnose this problem.  It sounds like a water valve is not opening up.
Posted on Sep 29, 2008
Why do Whirlpool Duet washers have such a problem with "over sudsing"? And how to prevent it?
The "oversudsing" problem is usually due to operator error. These new front loaders require the use of HE laundry detergents. These greatly reduce the sudsing issue. They also require VERY LITTLE detergent. For example, a normal-size laundry load only requires 1-2 TEASPOONS of HE laundry detergent. Most folks use much more than that, causing a possibility of oversudsing.
See this link for more info.
What Is HE Laundry Detergent And Do You Need It
Aug 08, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Tip
HOW TO CLEAN A WASHING MACHINE
Washing Machines Need Cleaning, Too We interrupt this scintillating mechanical exploration of washing machine mechanics to bring up a very important matter: why your laundry might stink even after a fresh wash. It may be that your washer is dirty.
Regularly clean the top and door of the washer to prevent the buildup of dirt and detergent. When you wash very linty materials, pull lint from the tub after removing the laundry. Built up lint can keep water and detergent from properly circulating and soap deposits themselves may cause laundry to smell bad.
To solve this problem, fill the tub with water and add 1/2 cup of baking soda or 3 cups of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach.
A word of caution: Rinse the tub thoroughly before wiping it out with bleach. The combination of ammonia and bleach forms a potentially dangerous gas called chloramine. This compound can cause health issues ranging from mild skin irritation to digestive and kidney problems
Finally, run the machine through a complete wash cycle before you put any more laundry in. Hopefully, you were able to address your issue with these simple steps.
on Nov 03, 2011 | Washing Machines
I wash massage sheets and the oil is not comming out of the sheets with the HE liquid laundry soap can I use a none he degreaser without hurting the machine
Don't use non he detergent in washer dispenser it did mess mine up. But u can try adding a cup of white vinegar into the washer itself when you load it to help cut the oil from the fabric it works when I was pool towels in the summer
Jan 18, 2012 | LG WM-2277HW Front Load Washer
Which compartment do you put the laundry detergent?
First cup on the left when you open the drawer, it says main wash
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I make homemade liquid laundry saop and when I use
you NEED to buy real washing soap from a store. I recommend Tide because you may be mixing wrong ingredients or not adding something. If buying new/real soap doesnt work i would go to a sears or email sears at their website and tell them.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Laundry detergent drawer stuck
I had the same problem - the fabric softener cup cam loose and I had to break it to get it out and the new drawer cost me about $65 to replace. I hope you made out better than I did.
Dec 13, 2009 | LG WM-2077C Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Laundry detergent
Why do you want to use a special detergent??? Tide works fine! You just need to use about 1/4-1/2 what is used in the American machines. Now if you really want some exceptional laundry detergent like we use in Europe, buy Persil (google it).
Dec 10, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
