Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Change Cycle dishwasher stuck on rinse&hold can't change cycle
    Sergeant:
    Champion:
  • 324 Answers
Bad electronic control or stuck keypad
Posted on Nov 11, 2008
4 Suggested Answers
bigg t
  • 640 Answers
SOURCE: dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
Posted on Aug 28, 2007
  • 1632 Answers
SOURCE: dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
Posted on May 14, 2009
tattootech2
  • 72 Answers
SOURCE: Frigidaire dishwasher won't end cycle - will run
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Posted on Apr 07, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
My dish drawer is stuck on the fast cycle and am unable to change cycles on control panel
Take a damp clean cloth and clean the touch panel where you set the cycle. If this does not work try turnign the mains power off and back on. I am assuming by fast cycle you mean rinse. It is likely the heater unit has a problem which the controller might be sensing and preventing you from selecting the long cycles that use hot / warm water for wash.
May 17, 2013 | Fisher and Paykel 23 in. DS603H W Built-in...
I cannot figure out how to advance a cycle without having to go through the entire cycle. For example, I had a drain problem with my sink and the plumber put the rinse and hold cycle on for about 10...
Welcome to FixYa.
Your post doesn`t specify a model number, however on most Bosch dishwashers in order to change from "rinse & hold" to "regular" ( or any cycle ) simply turn the unit "on" and once the machine begins push the regular button twice.
Or the button applicable to the cycle you want.
That should change the display to look like this...
If this doesn`t work, try it for "econo" or any alternative and let me know how it goes.
Good luck.
Regards,
Macmarkus :)
Sep 03, 2010 | Bosch Dishwashers
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Our dishwasher goes straight from rinse to the endwithout going through the washing cycle. How do I change the cycle? Have tried holding the button to change the cycle, but doesn't change. The dishwasher...
It turned out that the pipe bringing the water into the machine had a kink in it. We pulled the machine out and straightened it. A dishwasher technician suggested we look to see if the pipe taking water away from the machine might be the problem, but it was the incoming water pipe.
Jul 24, 2008 | Dishwashers
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
184 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
