JVC AV-28 GT 1 SJF tv with no remote
No remote control and the kids have managed to change the picture size. Is there a way to change the picture back to 16:9 by using just the buttons on the set itself?
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
TVtechmaniac
  • 140 Answers
SOURCE: The picture on my JVC TV is too dark
On the inside of the TV, on the flyback transformer there should be two controls. Turn the one that says "screen" very slowly clockwise while looking at the pix. The pix should get brighter as you turn it up- if you go to far you will see lines in the pix or the TV may shutdown.
Posted on Aug 30, 2007
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
redcrx
  • 7 Answers
SOURCE: JVC AV-28WFX EUS1 unstable image
Hello, I think you have a faulty "horizontal width" or horizontal
linearity preset pot. This pot will be located on the main PCB
and you can adjust it with a small screw driver, when you do the
picture will shift from left to right or vice versa, or move back to fill each side. If it wont hold after making the adjustments then the pots ( potentiometers) need replacing, which means unsoldering them from the printed circuit board( PCB) and take them in to your local radio shop for new ones. By the way you might need 2 pots ( 1 for the WIDTH and 1 for the LINEARITY)
Good luck.
Posted on Feb 06, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Jvc 57 inch tv. kid did something to change picture size. now too large and bottom is cut off. aspect button on remote when pressed shows a red circle with a line through it.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Apr 13, 2010 | JVC AV-28-BD-5-Bl 28" TV
Jvc av-28gt1sjf
there is a card with the TV Turner that is causing this and needs to be changed its has a microprocessor that control functions of the set .
get it changed and your set will just fine .
have fun
Dec 28, 2009 | JVC AV-28GT1B 28" TV
Picture is too wide for TV
One of your kids has altered the setting for 'Aspect Ratio'. you will find it in settings menu, picture.
Aug 17, 2017 | JVC LT-23X475 23 in. EDTV-Ready LCD...
Cannot fix color without remote
Here's a link to order the original JVC remote controller for this model (AV-20220) from a major parts distributor if you need the remote to fix the colors on your unit:
JVC AV-20220 Replacement Part Remote Controller / Remocon Unit
Feb 12, 2009 | JVC AV-20220 TV
Wii tune in on sony kv 28 fx
sir u can connect both as front n back,connect only on av input n select the av button in your remote once u press u can view the first input then as followa second
Dec 26, 2008 | Sony KV-28FX60 28" TV
Good luck.
Feb 05, 2008 | JVC AV27F476 27" TV
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Feb 24, 2007 | JVC AV-28-BD-5-Bl 28" TV
Jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Jun 07, 2006 | JVC AV-28GT1B 28" TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
