Question about Brother Office Equipment & Supplies
I have a Brother PT-8000 label amker and when I go to print a label it comes up cutter error??
  • 624 Answers
SOURCE: labeling system trouble-shooting
This is a duplicate post, click on the following like for the original:
Posted on Mar 04, 2007
  • 5 Answers
SOURCE: brother Model Pt-65
There are two vertical fonts - small and normal. To put the labeler into vertical mode, hold down the [Code] key and tap the [J] key.
When it asks " 1-9 ", let go of the [Code] key.
Press the [8] key if you want small vertical type, OR the [9] key if you want normal size vertical type. Then you have to hit the [ <--' ] enter key.
Now you are stuck in Vertical mode ! :-O
To get back to normal, hold down the [Code] key and tap the [J] key, Let go of the [Code] key.
Then tap the [3] key and the enter [<--'] key. You are back to horizontal labelling.
:-) phew!
Posted on Jul 28, 2008
SOURCE: Printing labels
You have to feed the labels through the manual feeder.
Posted on Oct 30, 2008
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
  • 1564 Answers
SOURCE: I think it ran out of ink, do I need to add ink to
I believe that this is a therm printer. Which means that the paper does the work it is heat sensitive and the keys warm to print. I'm not entirly sure about this but a quick way to tell is if the paper/tape is glossy on one side and flat finish on the other.You can obtain the owners manual by going to the Brother site and looking under support for downloads. It should be there after you've entered your model #. Thanks,Dana
Posted on Aug 16, 2009
P-Touch 7100 cutter error
Just a (too late) suggestion: The cutter on the PT-7100 (and I think on every Brother Label printer that uses TZ tapes) has a replaceable blade. Sometimes just removing the blade and making sure the tape path is clear of gunk is all it needs.
Apr 07, 2015 | Office Equipment & Supplies
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
Cutter missing or lost, can I replace?
The lever for the cutter is #UB3740030, and the whole print assembly is UB 3943001. Not too hard to replace, just a couple standard phillips screws.
Oct 22, 2009 | Brother P-Touch PT-15 Thermal Label...
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
My PT 1280 won't cut. Can I get a new blade?
The parts list doesn't show a blade alone, part # LN6775001 is the cutter lever, could be what you need. About $3.00
Jun 23, 2009 | Brother P-Touch - PT-1280 - Home and...
Brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Labeling system trouble-shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
James Cagle
James Cagle
Jim Keysor
