Cable connection broke off. do i need to take to tv repairman
  • 374 Answers
Not if you have other input source such as composites which are red/white and yellow. You can buy an RF modulator and plug the cable into it and run composites to the tv from the modulator. You will need to know how to get to the proper input though.
Need additional help just post a comment to this solution and I will get back to you asap. Hope this helped you.
Posted on Sep 11, 2008
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
Cable connection in TV broke off
That part is soldered into the TV circuitry. Chances are that a TV repair professional will need to open it up unless you know someone that knows how to desolate and solder in a new plug. If the circuit board is damaged, then you will have to source a new part.
Oct 20, 2014 | Seiki 32" LED TV - SE321FB
The antenna connection broke off
If the cracked portion is on the cable then you need to get the cable recrimpted with another connector. You can do this yourself but this needs a special tool. Ask your cable provider to get the proper connector reapplied.
Dec 28, 2013 | Sanyo DP32649 31.5 in. TV
Green squares on LG tv
Is this or does this happen to all channels. First check the connection on the back of you TV is it tight and secure. Second You may also need a new decoder from warner cable to view. (Channels are scrambled) and third look for TV repairman.
Jun 01, 2013 | Televison & Video
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Apr 01, 2009 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Televison & Video Logo
Top Televison & Video Experts
