Question about Fuji FinePix 2650 Digital Camera
Camera-video mode My camera is stuck in video mode. Everything else appears to work
  • bourbon May 11, 2008
    My camera is working only it will not go to photo image even when the mode is set to image, it is taking movie clip and audio ok but there is a problem with the image. I have also noticed that when I download to PC the file SSCAM is missing only DCIM appears.
  • 513 Answers
Is the button stuck? can you turn it back to the left position with the still camera icon? does it turn but stays in video mode? If its just a stuck button, put some special electronics lubricant on it(NOT WD 40!!) and try gently turning it, but it might be a better idea to open it up and work on whatevers keeping it stuck, if you dont trust yourself with it then take it to a reapir person or leave it alone - you're better off keeping your little video camera than nothing at all. If the button turns but the mode stays on video, try a reset/ try removing the batteries for 24 hours, then putting back again/ try new batteries/ try a new mem card. If all fails, use the warranty if you have it, or get a repair estimate and decide if its economical for you or not. Good luck
Posted on Apr 11, 2006
    Novelist:
  • 130 Answers
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Posted on Apr 10, 2006
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Video/movie mode stuck
Have you tried to reset the camera?
Reset switch is on battery compartment you will need a small needle or toothpick. Let me know if this works!
Jan 02, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Everything appears to be working on my camera however i cant see anything on the viewfinder its always black. I can look at pictures ,take pictures with flash, but they are black, please can you advise
If your camera is an SX110 IS, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
However, if you made a typo, and your camera is really an SD110, the problem would then likely be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Feb 16, 2010 | Canon PowerShot SX110 IS Digital Camera
Panasonic dvd video camera vdr-d100: How to switch to usb mode?
you cant put the information on with the ac adapter which is behind the battery with 7.9v so u will need ur ac adpater while u are loading or it will not connect and thats what usb mode means. if you dont understand atleast phone the panasonic helpline because they have just helped me.
thanks.
Aug 27, 2009 | Panasonic VDR-D100 DVD Camcorder
Polaroid i737 doesn't have a setup menu
The camera was "Q-Mode", which causes only an abbreviated menu to appear.  By taking the camera out of Q-Mode, which is done on an entirely different menu and not made clear at all in the owner's manual, the Setup menu is available.  The Setup menu is the key to everything in this camera, so my advice is to not keep the camera in Q-Mode.
Dec 25, 2008 | Polaroid i733LP Digital Camera
Faulty d40x
I would start by looking at all of the push buttons on the camera. One may be stuck down.
Jul 23, 2008 | Nikon D40x Digital Camera
R707 locked in the video mode
remove battery pack and memory card then replace should work.
May 05, 2008 | HP Photosmart R707 Digital Camera
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Fuji FinePix 2650 Digital Camera Logo
673 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
