Question about Panasonic PanaFax UF-8000 Laser Fax
Enable Scan on UF-8000
To enable scan on UF-8000 does an SD memory card need to be installed?
  • farquharsonm Sep 11, 2008
    Thanks for the replys. Is the ifax/scan key and or network scanning kit the same thing. I looked it up further and it looks like what I may need is the "Panasonic UE-404090 Internet Fax/Email/Network Scanner Kit." Would you agree?
  • farquharsonm Sep 12, 2008
    Is the ifax/scan key software or hardware. Where do I get this? Where on the machine is it enabled or installed?
    Sergeant:
  • 284 Answers
To scan from a uf8000 you need the ifax/scan key no other way to do it and a memory card doesnt help
Posted on Sep 11, 2008
  • Paul Homuth
    Paul Homuth Sep 17, 2008
    the ifax/scan key is a hardware attachment. you need to talk to your dealer who you got it off of. or if your in canada i can suggest a dealer
  • Paul Homuth
    Paul Homuth Oct 02, 2008
    its installed on the main board and needs to be purchased. if your in canada i can give you some dealers
    Genius:
  • 2,120 Answers
No (but, but it can't hurt!) If you are are attempting network scanning, you need the optional Network Scanning Kit.
If you want to scan to a single PC, that will work right out of the box.
Posted on Sep 10, 2008
  • Leroy Elliott
    Leroy Elliott Sep 11, 2008
    Yes,
    That is what you need. If you want to pop in a cheapie 512mb SD card (any brand) you can have additional email addys stored.
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
How to set the speed dial for the uf-8000 fax
Press
Function
74
set
119 enable one touch numbers
set
stop
Function
72
set
press a yellow key such as 01
enter fax number
enter name
set
press yellow key 02 to continue or stop
Jan 28, 2010 | Panasonic PanaFax UF-8000 Laser Fax
HP C6280 won't let me scan to the computer. Only options are "Scan & Reprint" or "Scan to Memory Card". I just want to save image directly on my computer but it doesn't let me. I've uninstalled and...
ergo your problem!!
You must have scanning software installed on your PC in order for the 2 devices to communicate. It should have come bundled on the CD you got with the printer. I believe the HP software is called HPDirector.
Please find on your PC or install from your CD & that will enable you to scan to your PC.
It may already be installed. You will need to run the software to enable communications between the 2 devices.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
We use the Panafax UF 8000 only as a fax. Can we use it to scan?
The Network /Email Scanner Card is an option. You can, however, use the Panafax as a Network Printer.
The printer driver is on the Document Management CD.
Nov 20, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Scan problem
is the com utility running
is a new firewall installed
May 07, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Scan to email
you need to check that you have properly programmed your parameters in the machine that should match the ones provided by your ISP.
Aug 14, 2007 | Panasonic PanaFax UF-8000 Laser Fax
Fax
Keep pressing function key
May 17, 2007 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
215 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
