Question about Home
Toilet tank often refills by itself
Hi, I'm looking for a solution to fix a toilet that flushes by itself at regular intervals. It seems as if the water level was slowly going down - although I don't se any leak inside or outside the bowl - triggering the system to "refill" a bit once the level is under the threshold.
I'm pretty sure this is a recurring problem and I had it fixed by a plumber some couple years ago - but it's coming back, so I'd like to see if I can understand and fix the problem myself... with your help :-)
I can't find the brand or model on the ceramic, but I'm attaching a picture of the inside of the tank if that helps.
Thanks!!! JJ.
  • J.J. Enser
    J.J. Enser Sep 12, 2008
    Thanks for the input, it looks like I should be able to manage. I'm no expert (obviously, otherwise I wouldn't be posting this) and I'm also not an English native speaker, so let me ask you for some terminology clarification to avoid any major damage :-)
    The faulty part, the "flapper" is the grey round piece of rubber that keeps the water from going down?
    Also, I'm not sure what you call "eyelet" to be careful not to cut... is it the little "arms" of the flapper that keep it attached to the vertical pipe?
    Finally, you're talking about replacing the handle. It that the metal arm.
    For more clarity, I've annotated my initial picture. I have also indicated what I think I remember being replaced the last time (clearly the part that looks newest in the tank).
    Thanks for confirming or correcting my assumptions. It's possible that I got everything wrong!!
    Best,
    JJ.
  • Anonymous Nov 25, 2008
    One of four Eljer Canterbury one-piece toilets refills itself every 15-minutes or so. Thinking the problem was a bad flapper valve, I replaced it (and the ones in the other three toilets as well not knowing how old they were). Still refills. I have cleaned the flapper valve seal seat area and replaced the flapper valve again. Still refills. I removed the whole flush valve assembly, cleaned its seal surfaces, added Vaseline to the seal surfaces, and reinstalled the valve. Still refills. Today, I purchased a whole new flush valve assembly and installed it. Still refills. Water is leaking out of the tank into the bowl. The water level in the tank goes down and then the fill valve kicks in and fills the tank. You can actually see water trickling into the bowl after the tank stops filling. Any ideas on how to fix? Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi jj4help
I'm Harvey the Master Plumber.
You're looking for a solution to fix a toilet that flushes by itself at regular intervals.
No sweat. Sending me a picture was a great idea. I can see that you have a very common setup in your tank. Although there is no "permanent" solution, it is very inexpensive to fix every few years! Just buy a "flapper" anywhere. There are different colors to choose from, which reflects the different materials they are made from. Personally, I find the red ones tend to have the longest life span.
Proceed by carefully cutting off the center ring. Don't cut off the eyelets! The center ring would be used in a different toilet (this is where the picture really helps). Now the flapper will match the configuration of the old one.
Simply turn off the water, flush, remove the old and install the new. Take note of the chain length. Set the new one the same by simply moveing the clip down to another link, let the extra chain hang. While you're at it, replaceing the handle at this time might be a good idea. It looks pretty old. If you do, remember that the hold down nut on the handle has reversed threads. That means it loosens clockwise (standard would be counterclockwise to loosen).
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
  • Harvey Goldberg Sep 12, 2008
    Hi JJ
    Thanks for responding.
    I've got answers for your questions:
    1. The "flapper" is the grey round part.
    2. Also correct about the "eyelets. When you buy the new red one you'll see the
    round piece between them, compare to old one and you'll see.
    3. Yes! Wheh buying a new handle it can be metal or plastic.
    Anyway if you own the house you'll know what to do next time, hopfully many years from now.
    Thank you,
Bemis two-flush toilet occasionally flushes by itself. How do I fix that?
Probably the flapper is not sealing, allowing leakage into the bowl. When the level in the tank drops sufficiently, the fill valve admits water to refill the tank.
Jul 04, 2017 | Bemis Home
What do I do to stop water from leaking from the tank, it refills itself several times, day or night? The toilet looks like a Sedona, although the shape of the tank differs a bit, the width is the same,...
Sounds like something in the floating device is bad so it doesn't shut off when filled. We just replaced our flush valve on ours because the toilet keep running.
Jul 11, 2011 | Toto Toilets ST784S 12 Sedona Beige...
Toto toilet
check the pipe connection from water tank
Mar 17, 2010 | Toto Washlet S400 for Power Gravity...
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Jan 17, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
Home Logo
3,203 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
