Question about Nintendo Wii Console
Wii - no display but has power
My Wii will power on (all lights display as expected) but no display on tv, ps2, work using same jacks on tv. No remote link screen and the remote/s will are not recognized. This happened after switching off from Need for Speed carbon. Any Advice would be appreciated
  • Techie-Pete Sep 12, 2008
    Thanks, m8 I used a working cable from a friends wII same thing. from speaking with my son, it seems to have crashed on exiting Need for speed Carbon, It may just need to reset back to factory defaults. is there such a method?
  • twinkle9 Apr 03, 2009
    I am having trouble getting my screen to display the wii*, the green light is on, and I have pushed the aux button , switching the cable to antenna/vcr tv* plus putting it on channel 3. I need help!!! because I haven't played the SIMS in a month!!!!
  • 250 Answers
Make sure that your video cable has not been damaged. you may have to get another cable to be sure.
Also, if you've been running the wii on the floot it's a good bet it has overheated and is has damaged the video processor.
Posted on Sep 12, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the same problem
the way to hard reset it is:
unplug the power cable for 5 mintues then plug it back in
didn't work for me but hey worth a shot
Posted on Dec 21, 2008
When I connect my Wii to my Yamaha HTR-6130 through the front V-Aux jacks, i hear sound but no image. It says " Listening to Dock" on the front display. Can you help?
On this receiver the tv must be connected to the Monitor RCA Composite (yellow) output in the rear when you use another Composite input. You can't connect the Wii with the Composite and expect to use the tv with the HDMI - this unit doesn't have an onboard converter.
Once you have connected it correctly just select as a source the front connectors.
Nov 28, 2010 | Audio Players & Recorders
Having trouble with the colors on my WIi, everything seems yellow and there is no red anywhere
I just wanted to add that I recently bought a WII and I have the exact same problem. I have a Samsung HD TV and I bought the additional HD cable that has the multiple jacks (i.e. green, blue etc.) I will post if I find a specific answer to the probem.
Dec 24, 2009 | Nintendo Wii Console
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
Wii remote will not work new batteries just blink all
Hey Jack, How many remotes are you able to connect at a time? If you have multiple remotes try turning the ones you know that work off, and putting them in another room(so you know they will not try to connect). Then try connecting with the bad one. If that doesn't work you might have to sync the remote: hold down the red sync button on the wii, located next to the sd card slot, while holding down the red button on the remote, located under the battery cover on the back. Now try connecting. If it still doesn't work, the LED lights in the sensor bar might have burned out, this happens a lot when you keep your sensor bar directly on your tv without the stand(the tv gets hot and burns out the lights), a lot of people do this because the stand looks bad. Go buy a new sensor bar, they sell them at wal-mart for $20, plus they're wireless, so you don't have to worry about that thin little wire popping. Test the new wii bar, if it's still not working, then you're remote is just worthy of getting returned.
hope this helps! -cj
Aug 21, 2009 | Nintendo Wii Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Psp spot repair in mumbai :- 9819767710/9867635653 ?
what was that????don't u have any better prob. to ask.....
Jan 23, 2009 | Microsoft Xbox 360 Console
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Nintendo Wii box light is on but no picture or sound from my tv
sometimes just sometimes tvs are funny, some tv's call it a "input select" others call it a "mode" or simply "input" and some dont have any they just want you to goto channel 2 on the tv and go back one more channel.
ushally all these modes are listed on the remote.
is it the origional remote? or is it a universal remote.
try those things above look over the remote again see if anything resembles any of that and if not
list the make and model of your tv and if your using a universal remote we will be able to figure something out for you.
Aug 12, 2008 | Nintendo Wii Console
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
1,097 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
