Philips GoGear HDD060  MP3 Player
Problem for Philips GoGear HDD060 (1.5 GB) MP3 Player
PHILIPS GOGEAR HDD060 DOES NOT TURN ON
By DEBS on Apr 09, 2006
I WENT TO USE MY MP3 PLAYER BUT IT WOULD NOT TURN ON. THINKING THE BATTERY MUST BE FLAT I PUT IT ON CHARGE.AFTER A WHILE THE SCREEN STARTED FLICKERING AND WOULD STILL NOT TURN ON. DOES ANYONE KNOW WHAT THE PROBLEM MIGHT BE?
Same Problem
Jan 23, 2009
-   cant disconnet from computer
-   lought
Jan 23, 2009
-   cant un connect from laptop mode
-   lought
Jul 14, 2008
-   well d prob is same it desnt get switched on niether it is being shown connected when i connect it to my laptop...........-   rockmehardst
Jul 13, 2008
-   it said to upgrade but when i took it off it didnt want to turn on -   leoass
Jul 10, 2008
-   I bought a new one delstar DS 2852 last week and i never could turn on , i want to know when can i buy a new battery, the model of the battery is 383040s. I bought it in Brandsmart in miami and i live in the caribbean..pleasa let me know if you can help me with this...
MC-   Guest
Best Solution
posted on Mar 17, 2008
Helpful)
ThaMp3Doctor
Rank: Guru  Philips Expert
Rating: 86%, 4644 votes
Here's a better solution - no offense, silly girl. First, find out if the computer will recognize the GoGear when you plug it in. If so, then use the Repair function in the Philips Device Manager.
If the computer doesn't recognize the player: Disconnect the GoGear from the computer, and turn the player off. Hold in the volume + button and continue to hold it as you re-plug the GoGear back into the computer. After 45 seconds to one minute, Windows will go into recovery mode and resucitate your player.
Also, the number for the Manufacturer - Philips - is
1-866-PHI-LIPS (or was it 1-888? - one of these is an adult line, the other is not) :-)
-Tha Mp3 Doctor
Was this helpful?
Yes
No
Solution #2
posted on Apr 11, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3615 votes
If you had it for 2 years or more then its not surprising that the battery would start acting up.
some specialty stores make a living out of supplying custom batteries for PDAs, since the originals cost half as much as a new one, but they're not always so easy to find.
Try leaving it charging for 24hrs, and don't touch it. If it doesn't solve it then that's it, unless you manage getting a relpacement battery. Personally I would think 5 times before buying anything with an internal battery.
Good Luck!
Comments:
Apr 11, 2006
- "half as much as a new one" I meant a new device...
Was this helpful?
Yes
No
Solution #3
posted on Apr 20, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I bought one a couple of years ago, and I found it doesnt like heat of any kind. It's as if it shorts out when it heats up.
Jack
Solution #4
posted on Mar 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
this sucks it doesnt want to not even turn on or flicker
Solution #5
posted on Feb 11, 2008
Not Rated)
avid_imps
Rating: 86%, 411 votes
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Was this helpful?
Yes
No
Solution #6
posted on Mar 18, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
mine is acting the same way but i only got it last xmas 2006 has yours worked yet or have u found a new battery
Popular Solutions for Philips GoGear HDD060 MP3
Questions and Unsolved Problems for Philips GoGear HDD060 MP3
Do you recommend Philips GoGear HDD060 (1.5 GB) MP3 Player?
Answer
Answer
how do i access music submenu so i can plaly downloaded music?
Answer
I plugged up my MP3 to my computer and it says ok to disconnect. When I disconnect I turn my mp3 on... (More)
Answer
i have philip gogear i pod model no. SA3025/97. When it starts it says connect to pc and repair... (More)
Answer
hat video files are supported on the philips gogear sa3025?
Answer
my philips gogear mp3 turns on an then turns off before it starts how do i fix it
10 Other Users Have The Same Problem - Continued
Comment by njs40, posted on May 19, 2008
i press reset button
i press play/pause button long time
but problem still yet
Comment by Guest, posted on May 17, 2008
i tryed to look for sites to fix it
Comment by Guest, posted on Mar 06, 2008
C`est bizarre pck quand je le connecte a mon ordi il ya des fois ou il reconnait pas et puis je peux pas mettre de la musique et le plus pire, je peux pas l`ouvrir du tout alors.G essayer de le formater ou initialiser mais en vain
Comment by Guest, posted on Mar 01, 2008
Hi
Yep, same problem, just a flickering screen, and I can't find anywhere on the web that looks like I can buy a replacement battery.
Philips just said get in touch with your local service centre, and I can't find one of these either....
Comment by fitmom43, posted on Feb 19, 2008
i have one that will also not power on..... this must be an issue with these. any rca #"s where i could call and get some assistance. i have been all over the web and the one # i did find is no longer a working #
LINDA fitmom43@yahoo.com
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
