Sony FD Trinitron WEGA KV-32HS500 32" TV
Problem for Sony FD Trinitron WEGA KV-32HS500 32" TV
Does not come on.
By corky on Apr 09, 2006
the red light keeps flashing. sometimes I've been able to get it on by unplugging then plugging it backin.
Same Problem
Dec 04, 2007
-   won't go on. Standby light flashes 7 times and keeps on flashing. Nothing goes on. Once in a while you can hear the TV go on after a surge of static. Then when you shut it off, it won't come back on.-   Guest
Nov 14, 2007
-   My tv did the same thing for a long time, by turning off by itself after being on for a while but now it just doesn't come on at all. It sounds like it is coming on but there is no picture and no sound.-   tericsson
Solution #1
posted on Apr 09, 2006
Very Helpful)
techman
Rank: Guru  Sony Expert
Rating: 86%, 7647 votes
Sounds like you have a shutdown condition in the power supply section.Your gonna need a service manual a vom and possibly a good scope. Theres not much you can do as too look at it and see a bad part. And theres not alot you can check staticly without a service manual. Although there is a common problem with this chassis as were in some of the older models of sony.. the Horizontal driver transformer as well as the regulator ic has a cold solder joint on them. Good luck
Was this helpful?
Yes
No
Solution #2
Helpful)
Jexx
Rank: Guru
Rating: 85%, 266 votes
Additionally, the number of times the LED blinks is a code as to what the problem is specifically.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Oct 19, 2007
Not Rated)
svmnew
Rank: Apprentice
Rating: 0%, 0 votes
First, you have to grab your tv remote then press:
Power, 5, VOL (-), Power
Self Diagnostics screen should come up.
That is as far as I got. I don't know how to interpret these codes.
If anyone can help me any further, it is greatly appreciated.
I have KV-27FS320 and my diagnostic screen looks like:
   2: +B OCP         0
   3: +B OVP     N/A
   4: V STOP         0
   5: AKB              0
   9: ZCD           255
101:WDT           N/A
Thanks to Ron Purkisher and Dave Wreski for getting me this far. (http://www.iwaynet.net/~nesda/SonyBlink.html)
Was this helpful?
Yes
No
Solution #4
Not Rated)
svmnew
Rank: Apprentice
Rating: 0%, 0 votes
My diagnostic screen looks like:
   2: +B OCP         0
   3: +B OVP     N/A
   4: V STOP         0
   5: AKB              0
   9: ZCD           255
101:WDT           N/A
Thanks to Ron Purkisher and Dave Wreski (http://www.iwaynet.net/~nesda/SonyBlink.html)
Was this helpful?
Yes
No
Solution #5
posted on Sep 21, 2007
Not Rated)
PeterKiryluk
Rank: Guide
Rating: 90%, 18 votes
This is what you should do, call Sony TV techs 1888,989,7669 give them the model and serial number then tell them how many blinks, they will suggest IC-numbers on the Silicone board, See if you can locate them, its is a commen problem they already know about it, then before u hang up as for the part number then u can cross refference the sony part number with the accual part number. They will give u numbers then u have to figure out what they are maybe its on the part itself if u can make it out. Then find a parts distributor and replace them. Most likely the parts range from 6-12$ just becareful with the board, make sure u dont break of any small resistors. Or if ur not really tech savy should take it to a local service tech
Was this helpful?
Yes
No
Popular Solutions for Sony FD Trinitron WEGA
Questions and Unsolved Problems for Sony FD Trinitron WEGA
Do you recommend Sony FD Trinitron WEGA KV-32HS500 32" TV?
Answer
Answer
When I try to turn on the tv it pops and then the "standby" light comes on...how can I fix...
Answer
hello i recently bought a bush 32inch full hd tv and ive had it about 24 hours. WHne i turn it on... (More)
Answer
When power on, the standby led flicks continuously? what is the problem?
Answer
Sony Wega 36" TV - color flickering on and off. It's about 8 years old.
Answer
I had it working great. Turned it off and walked away and now it won't turn back on. It trys to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
