Question about Texas Instruments TI-83 Plus Calculator
Black screen When I insert the batteries and press the ON button the screen turns on but it is black. Nothing will happen and none of the keys are responsive. It will automatically turn itself off after a short period of time. HELP!!!
  • 2 more comments
  • idontevenkno Sep 13, 2008
    My screen does that too, when I turn it on the entire screen is black..but it doesn't turn itself off the screen just stays black. And I don't really know what to do about it because even if I press keys, they may be working but i can't SEE to fix the problem
  • WilliamTShaf Sep 13, 2008
    My screen is covered with little black dots. I feel very frustrated. I can not get anything else. Thanks
  • nkf902 Sep 13, 2008
    I have this problem too and the solution is not that the contrast is too dark. It's so frustrating!
  • Barty08 Sep 16, 2008
    All i can see is a black screen, i have tried everything possible! Nothing seem to work!
Try 2nd Down Arrow. Your contrast may be turned up too high. This can appear to happen with new batteries.
Posted on Sep 11, 2008
  • howesbrad
    howesbrad Nov 07, 2012
    Thank you good sir, that's exactly what my problem was.
  • howesbrad
    Thank you. That was exactly what my problem was.
Samsung Intensity 3 wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 05, 2012 | Cell Phones
Side lx won't turn on
5.Wait 10 seconds.
Step
Thanks
Nov 01, 2012 | T-Mobile Cell Phones
My TI-89 Titanium is stuck on the main screen and no matter what button i press nothing happens. I have tried changing out all of the batteries and nothing is working.
Hi
when you turn on the Calc press the 2nd button and if the busy indicator is on its and hardware problem or if none of the keys is working
let me know if you want to fix
ecrdn@yahoo.com
Jack
Jun 26, 2011 | Texas Instruments TI-89 Calculator
My laptop screen doesn't come on tho the power is on. Fan seems to be on. Cd player ejects and it loads my iPod. I did give it a restart command and it didn't respond so I shut the flap and when reopened I...
1. Remove the system completely from power by removing the battery and AC cable 2. Wait a few minutes then insert battery ONLY 3. Power system back on while continusly pressing the spacebar 4. If screen does not appear within SEVERAL MINUTES wait time please turn off by removing battery 5. PLUG BOTH battery and AC cable in and repeat above process 6. If still nothing happens, please return to me for additional help.
My username is bbl242003, just add a comment if need be.
Please do not forget to ACCEPT the best answer
Jan 09, 2011 | Gateway Computers & Internet
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
I am so confused because i can´t turn on my iPhone the screen is still black This is what i tried... 1. Pressing the Power Button (Result: Nothing happens.) 2. Pressing the Power Button and the Home...
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
Jun 12, 2009 | Apple iPhone Smartphone
Nothing happens on my dash
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Apr 03, 2008 | T-Mobile Dash Smartphone
Screen is all black
Try adjusting the brightness by pressing 2nd key or witchever name is on yours for the Alt key + the up or down arow key(as you see fitted)
Aug 25, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
199 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
