Question about Amana ABB1927DE Bottom Freezer Refrigerator
Touch Temperature Controls not working
RE:Amanda ABB1927DE Refrigerator The refrigerator stopped running. The light inside is working and the outlet has power. The Touch Temperature Controls show a "dash line" for both refig and freezer and the temperature control pads do not respond to input. please help.
  • 1 more comment
  • Anonymous Jan 25, 2008
    The LED for the refriogerator says "Er", the LED for the freezer says "FF", and the touch controls don't respond. The freezer sems to be holding tmeperature, but the refrigerator is definitely warmer than it should be. I really can't tell if there is any colling in the refrigeratyor section.
    I have tried pushing the buttons, but i really don;t know what else to try
  • P C Jan 26, 2008
    Our 4 year old Amana appears to have the same problem.
    The refrigerator and freezer section stopped cooling and the inside
    temperature reached 60 degrees by the time we found out refrigerator
    had stopped working.
    There was no power failure!
    The refrigerator was on, the lights all worked, the LED display was not
    showing numbers. The display showed just a dash on each setting.
    Also, trying to change the settings did not work. The controls did nothing.
    They displays both kept showing a dash. The pump was not coming on.
    We lost lots of food.
    I unplugged the refrigerator and plugged it back in. The refrigerator
    then showed numbers, the pump started, and the controls worked
    again. It's like I rebooted the refrigerator's computer. The refrigerator
    got cold again, The freezer was back to working.
    BUT, is my refrigerator reliable?
    I have scheduled a visit from the Amana repair center. We'll see what they have to say.
  • jat12151 Sep 19, 2008
    we lost power and when power came on the freezer will get cold at the bottom but not at the ice maker.model #asd2626hes.what can i do.
    thanks
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Posted on Aug 01, 2009
Take fridge to a specialist and cut the ****!
Posted on Jan 24, 2008
Unplug the refrigerator and plug it back in again, then reset the temperature controls.
Posted on Sep 19, 2007
Try and look where the doors attach on top. Take the panel off from there and check the connectors. The touch pad connectors probably came apart.
Posted on Nov 02, 2007
    President:
  • 3,130 Answers
Do you know where to find the defrost timer?? If so theres a turn screw to advance the timer to start the compressor on as sometimes the motors burn out in the middle of a cycle and prevent the compressor to resart when the temp drops.
Posted on Apr 09, 2006
SOURCE:
How does to defoze refrigerator
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 02, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
I have an Amana Model ARB2214CB Refrigerator with the bottom freezer. The unit runs fine but the last three months for about a week it stops cooling and the freezer stops freezing. You can hear the fan...
That sounds like a defective=> 67001036 Defrost Timer
slowing down and sticking in it's defrost position on the timer cam. The defrost timer can be found inside the fresh food section behind the controls. See=> ARB2214CB Controls location #12 in the photo HERE Questions? Thanks John Tripp Appliance 911
ARB2214CB User Manual
Feb 20, 2014 | Amana ABB1927DE Bottom Freezer...
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
Our refrigerator is freezing items in the refrigerator with the temperature set at 40 degrees. Do you know why?
You need to test the thermistors in the unit. It should read around 10,000 ohms at room temperature and around 29,500 ohms at 36 degrees. If it is not reading properly, you will need to replace the thermistor kit. Here is the kit to order.
The thermistor is located in the light assembly.
Nov 18, 2012 | Amana ABB1927DE Bottom Freezer...
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Hi I have a amana bottom frezer model number abb1922feq that runs all the time even when I turn the controls off the compresser stell runs and the coils freeze up so the Refrigerator dues not work ?
sounds like the control board is bad part 12868513,there is no timer on this fridge and it sounds like it's not going into defrost,this board controls this,it's located in the fridge section inside where your touch pad is,i'm pretty sure you have to take down the light cover to get at it,it's been a while since i've changed one,good luck
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Temp Controls Stop Working - Show Dash - Food Spoiled
could be a glitch in the defrost cycle the adaptive defrost control could be faulty and when you unplugged it you might have reset it it should be ok till monday but i would just get the basics untill the tech looks at it
Jan 26, 2008 | Amana AFD2535DES French Door Refrigerator
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
1,145 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
