Question about Cell Phones
It worked for a while and I was able to recharge it, but now it won't hold a charge.
  • Cell Phones Master
  • 32,281 Answers
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Sep 01, 2011
  • Jc Cluxton
    Jc Cluxton Jan 11, 2017
    Mine does this same thing but I have a tablet not a cell phone can't change battery's what should I do?
2 Suggested Answers
SOURCE:
  • 252 Answers
SOURCE: I have a philips se
well it very well may see they rate batteries in mah normal duracells and thing are usally only 800-900 mah milli amp hours a good rechargable battery can be from 2200mah i have seen them up to 3200 mah for phones so yes a rechargable battery would last longer in the phone as they have a higher mah or in simple english longer discharge time
if it helps please give 4 thumbs up it helps me continue to help all of you thanks
Posted on May 12, 2011
My battery for my mp3 won't last long
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 16, 2012 | Coby Audio Players & Recorders
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
Nwz-w262 battery will not hold charge
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
I just bought the eclipse cld and it won't turn on after charging for hours
Sep 30, 2012 | Eclipse Audio Players & Recorders
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
Battery not holding a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Since you did not supply details of your device and the type of battery I cannot advise where to purchase the battery.
I suggest you Google the Internet for the rechargeable battery you require.
Apr 15, 2012 | Televison & Video
Sony vaio vgn-nr285E battery won't hold a charge
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
Cell Phones Logo
791 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
