Question about HP DesignJet 1050c plus InkJet Printer
Error 0c0030 00000088
Can someone tell me what this is?? i have repaced the printheads but still get thsi error
  • HP Expert
  • 141 Answers
That error sometimes means that there is a leak in the tube system, causing air to enter the printheads thus further causing the printheads to dryfire. have you noticed that you have been replacing printheads more often than normal. if you have ruled out the drop detector and are still getting the error, then replace the tubes. you may have to replace one or more printheads as well because dryfires permenantly damage the nozzles. Good Luck!
Posted on Sep 21, 2008
That error indicates that the drop detector is not working. If a Print Quality test shows that the pens are working and nothing is blocking the inside of the drop detector, perform the Service Station calibration. If the error doesn't clear, then replace the detector assembly.
Posted on Sep 11, 2008
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Nov 26, 2014 | HP Designjet Z6100 InkJet Printer
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 5200 on start up of Cannon MP830 printer
Error 5200 on the MP830 is for a printhead temperature warning. The Canon service manual suggests two causes of action. Firstly replace the printhead or secondly the logic board. Printhead can be replaced at a cost (Part number QY6-0061-010 about £50) but if you know someone with the same model try their printhead first because it might be the logic board.
Thanks
Jan 04, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon printer S200SPx error code 5600
The user manual does not talk about specific error codes. From other forum I belong to, it looks like it may be a bad printhead. If that is it, Canon says to call support. I suspect the cost of a new printhead would be more than the printer is worth.
Jul 31, 2009 | Canon S200X Ink-Jet InkJet Printer
Replacing printhead on Kodak ESP 5 Printer
you need to lift printer front access door , take both ink cartridges out,
the carrier (black piece) is called printhead.
When you see carefully at the center , there is a gray latch. you need to "pull it up", it will release the printhead.
MS
Jun 12, 2009 | Kodak ESP 5 Printer
5500 kodak printhead repacement
Above the thumb print in the printhead there is a button. Press button and printhead releases.
Jun 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
Feb 06, 2009 | IBM Infoprint 1352 Laser Printer
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
Canon i850 7 orange flashes =Bad printhead????
I had the same problm the printer made loud noises, the head did not move and the light flashed orange. At the right most position where the print head rests there is a gear, gunk had the gear jammed I cleaned it with a paper towel lots of black ink came out, it is working fine for a couple of days now.
Apr 17, 2007 | Canon i850 InkJet Photo Printer
HP DesignJet 1050c plus InkJet Printer Logo
275 people viewed this question
Ben Johnson
