Peavy SP5XP speaker doesn't work - Audio Players & Recorders
2 Suggested Answers
My Peavy XR800F just had all its pots replaced and now iam getting very low output.. any ideas please ?
Output transistors or the preceding driver stages may be failing. Check for electrolytic capacitors for bulging tops, they will have to be replaced.
Sep 09, 2016 | Ideas Music
HOW DO I GET THE SPEAKER OUT OF A PEAVY KB-100 CABINET
You remove the speaker grill cloth frame from the front of the amp. The entire frame is held on by velcro onn the corners of the face of the amp. Once off, there will be 8 philips head screws holding the speaker into the cabinet.
Dec 23, 2014 | Music
My 2600 amp runs hot shut off
Is the fan working, and is it ventilated? Are the speaker loads correct? Are there any speaker cables shorting?
Aug 08, 2014 | Lynn Peavey Lynn Peavy Stati-Lift Dust...
PB10 mixer
speakers i suggest something like sp 2
amplifier i sugest an intergrated amp with main in and pre out (in order to conect the mixer)
moinitor your choice
Mar 05, 2014 | Peavey Audio Players & Recorders
The SP5G Peavey Speakers are a good combination for the MP5 Plus?
Those speakers are capable of much more power than that little powered mixer can deliver - my 5G's are rated for 800 Watts program. I use a pv2600 to drive mine - at 8 ohms per side that's a good match. Depending on what your using the setup for...my concern would be that a small amp like that could get turned up high enough that you'll be clipping - thereby sending nasty squared waves at the speakers - they won't like that much. If you want much volume - you should look at a bigger amp. If you're going very low key...those speakers are overkill.
Jun 08, 2012 | Music
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
Caused speakers to smoke:(
If it's the speaker cabinet itself that';s smoking, you have most likely burnt some components in the passive crossover. Pull it out and you may see melted parts or scorching on the circuit board. Peavy does repairs on it's own products pretty reasonably if there's no local tech. Call Peavey Customer Srervice at 877-732-8391.
Apr 30, 2009 | Audio Players & Recorders
I need replacement 8" drivers for my Peavey PRM 308S Monitors. What would you recommend?
You have to use original manufacture parts if you want the orignal sound and specs. The crossovers and design of the speaker enclosure is matched for the speaker drivers. Start at the link below.
http://www.peavy.com/
Jerry G.
Apr 28, 2008 | Peavey CH1 Speaker
Connecting input & output on my TOA 900 series amp
http://www.toaelectronics.com/Manuals/P-906_12_24MK2.pdf.
Jan 07, 2008 | TOA Electronics P-924MK2 Amplifier
 Grubhead
Grubhead
