Question about Polaroid FLM-3732 Television
Polaroid FLM-3732 weak audio output
I have external (powered) speakers hooked to the audio out jacks, but the sound is very weak. almost nothing is going into the subwoofer. I have already changed the bad capacitors responsoble for the black screen problem, and the picture is fine now. I am quite capable when it comes to electronic assembly, but lack knowledge in circuit theory. Is there anything I might be able to change or fix, to possibly boost the audio output of these jacks?
    Problem Solver:
  • 8 Answers
Have you checked the settings in The Audio section, I don't want to sound silly or anything, but, I, myself, experienced this problem and, it was simply the set was set incorrectly
On another set I found a shorted output wire from the amplifier section in the sound board
Hope this helps
Posted on Sep 14, 2008
Tip
Polaroid FLM-3732 Service Manual Download
Download Polaroid FLM-3732 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3732 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3732 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3732 Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-3732 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3732 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3732 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Where can I purchase a power supply for my non functioning flm 3732 polaroid tv?
Have you checked Ebay?
http://cgi.ebay.com/MLT070AX-POLAROID-FLM-3732-POWER-SUPPLY-/120567221766?pt=LH_DefaultDomain_0
May 21, 2010 | Polaroid FLM-3732 Television
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-3732 Television
Tip
Follow this link
I hope that helps.
I have lost audio polaroid flm 3232m
Try to narrow down the bad section of the audio signal chain by hooking up powered PC speakers to the audio line out to see if you do get the sound there, if you do then the problem can be in the power amplfier section, if you do not get the sound at line out then it can be in the sound processing circuits, here is the service manual: http://www.polaroidsupport.com/polaroid/docs/FLM-Series-26-32-37_ServiceManual_20070418.pdf
Mar 13, 2010 | Polaroid FLM-323B Television
I have video on my Polaroid FLM 3932 but no audio. It just went out all of a sudden and didn't come back.
You need to test the audio output of the television on another sound source like the dvd or vcr player or fm tuner. If you find the sound work on these outputs. The problem you are having is with the television tuners audio reception. If you are not getting audio output from any source.The problem you are having is a complete failure of the audio circuits in the television. You can call Polaroids customer care service at this telephone 1-866-289-5168. Give them the model number of your television and tell them about the loss of audio output in your television. They will be able to tell you how you can obtain service for your television. I hope this information helps you with your problem
Mar 20, 2009 | Polaroid FLM-3732 Television
I have no sound on my 32 inch polariod tv none at all please help
What it sounds like is wiring inside to the speakers got disconnected. Does the TV have a jack for headphones or external speakers? If so, then I would connect something to see if you get sound.
If you still do not have any sound, then your audio outputs may have fried.
Jan 17, 2009 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
121 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
