Question about Panasonic PV-M1359W 13 in. Combo
Panasonic PV-M1359W 13 in. Combo II
I tried to reset the combo, but it WILL not turn on when I press the power button. REF: My combo wiil not turn on and all three lights (rec., on timer, prog timer) are illuminated in the front. Help!
  • freejesse Mar 16, 2008
    the t.v. was on, playing a dvd just fine, then turned off, and won't turn back on again. It has power. I press "on" and the red light comes on for one second, and then the things shuts down again. over and over, same thing.
  • Rich Ray Apr 09, 2008
    I have a Toshiba MD13P1 TV/DVD Combo. When unit is powered on, nothing displays on screen. When you press the DVD eject button, the screen displays for 1/2 of a second whatever show is playing on the whatever TV channel the TV is set to - then goes dark again. Unit won't stay powered on. Anyone else have this problem with a TV/DVD combo unit?
  • 513 Answers
A couple of easy things you could try is to unplug the TV from the AC over night, to let it discharge, and see if theres any difference, and also try to connect it to another power outlet. anything else is a bit tricky - if you have no electronic repair experience you should take the set to a repair shop. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Its possible that you got some dry joints, look for poor soldered joints on the high voltage side, and resolder them. particularly around the high-heat producing parts and flyback, h-driver and other transformers, etc.... and look for obviously burnt or mis-shaped components. Good luck
Posted on Apr 11, 2006
How do I turn off demo mode
To exit the self-demo mode, with the TV on, press and hold Play/Repeat for 5 seconds (possibly a bit more). If you press and hold the button again, you will go into the demo mode. Panasonic has the manual at their support site: http://www2.panasonic.com/consumer-electronics/support/Televisions/TV-Combos/Operating-Instructions/model.PV-C1320.O . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/PVC1320.PDF .
I hope this helps.
Jun 11, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
I have a Panasonic pv-c1320 without the remote. trying to get the code through comcast digital transport adapter need a 5 digit code
Here are some Panasonic codes that Comcast lists on their website: 21062, 20035, 20162, 20225,
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
Mar 16, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
What is the TV remote controller code for a Panasonic Model # PV-C1320?
Hello
Universal remote codes for Panasonic TV/VCR combo are:-
0374 0381
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Mar 04, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Need the remote se up coed for Panasonic tv.vcr combo model PV-2061. The nine 5 digit codes provided by Comcast do not work
Hello
Just try with these four digit codes
0374 0381
Direct Code Entry
NB: Switch OFF and switch ON your combo with its FRONT PANEL POWER SWITCH EACH TIME before trying an other code. OK.
Feb 17, 2011 | Panasonic PV-C2061 20 in. TV/VCR Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
I have a Panasonic TV/VCR combo my kids deleted all the channels out of it, and we don't have the remote. Tried getting codes from the cable company but didn't work. Model # PV-C1321A Model # 120V AC60Hz...
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Feb 18, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
No remote
The only thing that you are able to program without the remote is the language, channels, and time by pressing and holding the play and FF button for five seconds until the tv turns off, turn it on again and you will get what i just mentioned...
May 21, 2008 | Panasonic PV-C1320 13 in. TV/VCR Combo
Panasonic TV/VCR Combo PV-M1378W
My son did the same thing to his tv and to get it off you simply press and hold down the play/repeat button for approximately 5 seconds and then it will disappear from the screen.
Apr 19, 2008 | Panasonic PV-M1378W 13 in. Combo
hi reset the combo: http://www.fixya.com/user-guide/p231976,m7872,gm36/Panasonic-PV-M1359W363-in-Combo.aspx good luck
Apr 09, 2006 | Panasonic PV-M1359W 13 in. Combo
Panasonic PV-M1359W 13 in. Combo Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
