Question about Dryers
Dryer not working
The dryer stops running after minute or so, the water light is flashing although it is empty
  • lorainemcgee Sep 10, 2008
    thanks for that
    do you mean fluff may be stuck under the motor or the water sensor may need replacing
    many thanks
    Genius:
  • 1,239 Answers
Hi sir i think wastes are stucked below motor or the light sensor is damaged service it thank u,,,,,,rate it
Posted on Sep 10, 2008
My dryer stops after a few minutes and all the lights flash. It stops turning and doesnt get warm or hot in that time. I have cleaned all filters and emptied the water. Can anyone help?
I believe it has something to do with the computer circuitry. You might try to reboot it. Unplug your dryer for a few minutes, plug it back in and see if that works. It did for my washer. Good luck.
Feb 07, 2015 | Dryers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
Condenser dryer
PULL OUT THE PLUG
on the bottom right on the back is the water pump
it needs cleaning or replacing
not lifting the water to the water draw
Dec 12, 2013 | Creda IWD12 Front Load Washer / Dryer
Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
Top Dryers Experts
