Question about Dryers
Need to replace dryer belt for kenmore series 80. The dryer is apart dont know how/where the belt should be installed
    Genius:
  • 1,239 Answers
Hi the belt is attached to motor find below shaft the screws ,fix the belt again assemble it
Posted on Sep 10, 2008
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
How do i access and adjust the belts on a Kenmore Series 80 dryer
I dont think there is an adjustment, it will need a new belt and maybe a new belt belt tensioner. If the belt you have now is slipping I would replace with a new, then go from there.
Oct 26, 2009 | Kenmore Dryers
I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to Repairclinic.com and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Oct 23, 2009 | Kenmore 62622 Electric Dryer
Kenmore 80 series dryer makes a constant squeaking sound as drying modelnumber 110 70832990
could be rollers, idler, belt or motor, we have to tear it apart and manually move things to find out... simply visit my site and call if you need help whirlpoolpartssurplus.com mark
Jun 25, 2009 | Kenmore Dryers
Belt replacement
Visit youtube.com and type in Kenmore dryer repair. You'll find step by step instructional videos to service your unit.
BUT.... You've probably burned a belt, but this may only be a symptom of another problem. Something caused the belt to freeze up and burn on the motor pulley.
Check the roller bearings while it's apart... Make sure that the motor's turning free and all related rollers, pulleys etc are in good shape... save yourself from having to open it up twice..
Good luck and let me know how it goes.
k
Jun 22, 2009 | Kenmore Dryers
the buzzing noise sounds like the motor is turning,so then your belt is broken.take apart inspect clean and replace worn parts
Dec 31, 2008 | Kenmore 63942 Dryer
Kenmore Series 80 Dryer. Heats doesn't spin clothing. Imagine its a belt or spin motor. Need a schematic
No need for a schematic, there are two kenmore dryer belts, 'full size' or 'apartment size', if it is a belt you will be able to here the motor racing unloaded, turn heat to cold before testing, dont want to blow a thermal fuse.
Kenmore dryer comes apart from the front,
  • UNPLUG dryer 220V is not fun
  • remove the lint screen
  • remove the screws under the lint screen holding the case top to the screen holder
  • with a putty knife or other blunt blade release the catches at the front corners of the top and raise top
  • remove screws holding front of case on, from inside the dryer
  • remove door switch cables
  • lift front of case off and set aside,
  • can reach motor, belt, felts and rollers.
  • broken belt will be obvious, lying on the floor
If belt is broken, examine rollers and felt bearings for wear, stuck rollers or no felt left, is the most common cause of belts breaking, extra tension is required to spin the drum, If damaged replace them, they are cheap and easy to do, and it woud be no fun if another belt broke quickly
reasemble after repair in reverse order.
Aug 25, 2008 | Dryers
Dryers Logo
501 people viewed this question
Top Dryers Experts
