Question about Neff Dryers
Hi,my dryer does the cycle but the clothes come out slightly damp ,not sure what to do.thanks
  • 1,239 Answers
Hi sir i think your motor will not take heavy load so put water level normal it is the solution.........rate it
Posted on Sep 10, 2008
Why are my cloths warm but slightly damp at the completion of all cycles selected.
Good Afternoon Friend,
I understand that your Frigidaire dryer is leaving your clothes warm but slightly damp. I will be more than happy to assist you. So I am able to better assist, I kindly ask that you provide me with the model number of your dryer. Typically, this number is located on the back of the door, or possibly around the edges where the door meets your appliance. Looking forward to hearing from you.
Jul 09, 2014 | Frigidaire Dryers
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Zanussi T/Dryer - clothes damp
Check and clean filter/s, if it is vented through a hose, make sure it is not blocked or restricted in any way
Please leave feedback.
Nov 13, 2009 | Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer heats up but clothes not getting dry after several cycles
Hi, First thing you want to check is the 4" vent that goes to the outside. Make sure that it is clear of lint and that it is no pinched or kinked at all. Is this electric or gas dryer and what model is it?
May 16, 2009 | Dryers
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
LG clothes dryer (DLE7177WM) signals completion of cycle when clothes are still damp. This even occurs when 'Very Dry' option is selected, which seems to now be required.
Hi thanks for the question The easiest thing to check is the venting make sure the dryer is far enough from the wall so the vent wont kink check and see the air going outside is not restricted in any way . dirty vents can also cause fires especially in gas dryers thanks for the question the appliance doc
Sep 12, 2008 | LG Dryers
Smelly clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 18, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
90 people viewed this question
Top Neff Dryers Experts
ray gallant
Nicholas Tipples
Nicholas Tipples
Level 1 Expert
Are you a Neff Dryer Expert? Answer questions, earn points and help others
