Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave running not heating - GE Spacemaker JVM1640SJ Microwave Oven
  • 1 more comment
  • bauergirl Dec 31, 2008
    Our microwave popped popcorn for the granddaughters and then stopped heating. Everything seems to work. The turntable spins, the board is lit but nothing heats up. Can it be fixed or does it need replaced?
  • jvw36 Mar 14, 2009
    MY LG OVER THE RANGE MICROWAVE WILL RUN AND ALL THE LIGHTS WORK,BUT IT DOES NOT HEAT?
  • Anonymous May 26, 2009
    I have a GE spacemaker microwave Model JUM50001 which works at times and other times does not. Sometimes it will heat the plate only and not the food. I am guessing the microwave is approx. 25 years old. My problem is that new microwaves hang down too low over the stove. The particular model I have is angled which leaves additional room while cooking. Can you help? Dave
  • 706 Answers
If your micro is operating but not heating then you may have a bad magnetron, hv transformer or thermostat.. you can determine what you are willing to spend and if its worth it,, here is a link for the parts and an assembly drawing that may help.. http://www.pcappliancerepair.com/model-display.php Good Luck
Posted on Sep 13, 2008
My microwave over just stopped heating but runs like it is heating
hi , now that's either power supply to power the magnetron or the magnetron itself ...
Regards
Rob
Jul 15, 2015 | Kenmore Elite Microwave, Model...
Microwave runs but doe not heat
follow this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 26, 2013 | GE JVM1190 Microwave Oven
Sharp r-610dk microwave runs but don't heat up
The magnetron has failed, or the inverter board, "if 7 years old or less" there is also a possibility the keypad control board may be the problem.
Apr 21, 2012 | Sharp Microwave Oven Microwave Oven
Arching and sparking when run empty
microwave should never run empty. the reason is that the microwaves needs to heat something. more info : google - how microwaves heat food?
Dec 26, 2010 | GE JES1851 Microwave Oven
Microwave runs, turntable turns, fan runs, but does not heat,
No heat means the magnetron circuit has failed. It is the part that generates the microwaves to heat the food. Usually not worth fixing since the magnetron costs nearly as much as a new oven. To diagnose, if the oven is on, you will hear a loud buzzing sound if the magnetron is shorted.
Jun 30, 2010 | Sunbeam SMW777 Microwave Oven
Microwave runs but doesn't heat
Most likely shorted the transformer for the magnatron,Its expensive to repair and you should consider just replacing the micro.
Jun 01, 2010 | Microwave Ovens
Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
The microwave runs but doesn't heat?
heatman101
jke
Apr 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but will not heat
heatman101
jhj
Dec 15, 2009 | GE Advantium 120 Convection/Microwave Oven
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,434 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
