Question about Panasonic PV-M1359W 13 in. Combo
My combo wiil not turn on and all three lights (rec., on timer, prog timer) are illuminated in the front. Help!
  • Joseph Castillo Apr 09, 2006
    I tried to reset the combo, but it WILL not turn on when I press the power button.
    Champion:
  • 277 Answers
Hi reset the combo: http://www.fixya.com/user-guide/p231976,m7872,gm36/Panasonic-PV-M1359W363-in-Combo.aspx good luck
Posted on Apr 09, 2006
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Tv wont turn on
On a lot of the Panasonic units that is normal--idiot light that means nothing at all.
Some people actually cover it with tape so do not have to look at it.
Apr 29, 2012 | Panasonic PV-C2061 20 in. TV/VCR Combo
I have a Panasonic TV/VCR combo my kids deleted all the channels out of it, and we don't have the remote. Tried getting codes from the cable company but didn't work. Model # PV-C1321A Model # 120V AC60Hz...
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Feb 18, 2009 | Panasonic PV-C1321 13 in. TV/VCR Combo
Panasonic TV/VCR Combo PV-M1378W
My son did the same thing to his tv and to get it off you simply press and hold down the play/repeat button for approximately 5 seconds and then it will disappear from the screen.
Apr 19, 2008 | Panasonic PV-M1378W 13 in. Combo
Panasonic PV-M2738 flashing light
A BAD PCB (power control board) maybe cheaper to buy new combo
Jan 17, 2008 | Televison & Video
Loss of picture and sound repeatedly
You already hit the nail in the head,the problem might be the actual conector loose inside the set or the tuner has loose conections to the main board,the shell of the tuner is the ground make sure the conections are solid,if you are familiar with tv service this will help but if you are not too familiar be safe and call for help,right now it should not be expensive.
Oct 04, 2006 | Panasonic PV-C1321 13 in. TV/VCR Combo
Panasonic PV-M1359W 13 in. Combo II
A couple of easy things you could try is to unplug the TV from the AC over night, to let it discharge, and see if theres any difference, and also try to connect it to another power outlet. anything else is a bit tricky - if you have no electronic repair experience you should take the set to a repair shop. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Its possible that you got some dry joints, look for poor soldered joints on the high voltage side, and resolder them. particularly around the high-heat producing parts and flyback, h-driver and other transformers, etc.... and look for obviously burnt or mis-shaped components. Good luck
Apr 09, 2006 | Panasonic PV-M1359W 13 in. Combo
Panasonic PV-M1359W 13 in. Combo Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
